Timing belt tension
94 Accord LX Hey all. I changed my tensioner and timing belt and brought it back 3 cogs with the bolt loose and then tightened the bolt. I started the car up and it was fine but I heard the turbo charger noise (I don't have a turbo charger). I did this twice and still have the noise. I just took it to a mechanic and he said the tension is fine. I've been reading all over these forums that if you get that noise then your belt is going to break at 9 or 10k. What do you think? What should I do or what could be the problem?
wrsimmons21
May 21, 2006 03:47 PM
