zero'ing cam gears with milled head (searched!)
Old May 24, 2006 | 07:13 AM
luis666's Avatar
Default zero'ing cam gears with milled head (searched!)
i milled my head 30 thousands so I wanna make sure my cams are set 0,0 when crank is at TDC
ive read a post on this board a few weeks ago telling how to zero the cams... it had something to with with locking the cams at 0,0; loosening adjustable cam gears, and then turning crank until it reaches TDC.
does that sound right or did i just dream about that?
if its fesable, how do I lock in the cams so they dont move when I turn the cams sdo only the adjustable cam gears turn?
thanks
Old May 25, 2006 | 12:23 PM
PHDZINE's Avatar
Default Re: zero'ing cam gears with milled head (luis666)
The right way to zero in the cam would be to degree them in. Buy the Cam degreeing kit. Most people don't us this method but it's the right way to do it.
Old May 25, 2006 | 04:34 PM
2 0 3's Avatar
Default Re: zero'ing cam gears with milled head (PHDZINE)
degree those cams. its the only accurate way.
Old May 26, 2006 | 05:56 AM
luis666's Avatar
how much is a degree kit worth approx.?
Old May 26, 2006 | 09:26 AM
PHDZINE's Avatar
I think I payed $80.00 for my crane cam degree kit
Old May 26, 2006 | 07:50 PM
2 0 3's Avatar
check out http://www.newenglandhondarebuilders.com
mike belben sells a great kit. more than $80 bucks but its well designed and is made specifically for honda engine.. d/b/h/k series all available
Old May 26, 2006 | 09:40 PM
LSVTEC 91 Civic's Avatar
Banned
Adjustable cam gears are also an option.. There is math to determine how far to advance the cams with a milled head, but I lost that information.
Does anybody here have that info?
Old May 27, 2006 | 08:00 PM
Iceman05's Avatar
advance the timing one degree for every .011 milled
Slacker93eg
Mar 26, 2012 03:12 AM
killacam661
Feb 11, 2010 09:07 PM
MDintegra95
May 5, 2005 08:28 AM
DrewQ1
Mar 7, 2004 05:03 PM
Smoochy
Mar 28, 2003 04:06 PM
