o2 sensor issues
well i installed a new o2 sensor awhile bak and im reading about obd1 conversions for my ls swap, and there saying i should convert from my 2? 2 wire o2 sensors to the 1 4 wire sensor. well i havent started the conversion yet, but wtf? 2 o2 sensors? how did i miss that? i only saw one plug in the harness for the o2. and for some reason my ecu blinks the 1 code and its not even showing the cel, and then after a while of the car being on the cel randomly pops up. pics would help ALOT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efyou »</TD></TR><TR><TD CLASS="quote">thas nice...i have a b18a</TD></TR></TABLE>
which is probably why you never heard of that for your motor
well then...if im going to be puttin the the 4wire o2 sensor on there...the plug is gonna be different...would it run to the same place as my current o2 sensor plug? if so can i jus cut the plugs off and wire it directly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efyou »</TD></TR><TR><TD CLASS="quote">well then...if im going to be puttin the the 4wire o2 sensor on there...the plug is gonna be different...would it run to the same place as my current o2 sensor plug? if so can i jus cut the plugs off and wire it directly?</TD></TR></TABLE>
1993eghatch
Sep 24, 2010 05:52 PM
jdm1980
Mar 10, 2008 08:13 AM
racingant
12
Nov 11, 2005 06:41 PM
