Tranny mounts for dropping tranny, do i take out all 3 ?
Old May 24, 2006 | 05:22 AM
GarageAlchemist
Guest
Posts: n/a
Default Tranny mounts for dropping tranny, do i take out all 3 ?
I'm replacing my clutch and i'm a bit confused about what mounts i need to loose, it looks like the front, the tranny on thats near the wheel/side of the tranny and the back mount, but then wouldn't that drop my engine as well...
so do i put a jack under the engine, remove all 3 mounts, and drop the tranny with anther jack?
Old May 24, 2006 | 05:29 AM
fireant's Avatar
Default Re: Tranny mounts for dropping tranny, do i take out all 3 ? (GarageAlchemist)
When the effinmotorworks fellas did mine, we removed the front, rear, and passenger mounts. The engine was allowed to pivot downward, supported only by the drivers-side mount and the jack beneath it.
Removal is pretty easy, putting back is harder.
get some masking tape and a marker to help keep track of all the bits you pull off...there's alot of stuff.
Old May 24, 2006 | 05:33 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: Tranny mounts for dropping tranny, do i take out all 3 ? (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">When the effinmotorworks fellas did mine, we removed the front, rear, and passenger mounts. The engine was allowed to pivot downward, supported only by the drivers-side mount and the jack beneath it.
get some masking tape and a marker to help keep track of all the bits you pull off...there's alot of stuff.</TD></TR></TABLE>
rock, thought so, just a pita.. frigging bitch pin is a pita.. still gotta pop the axles.. ug
Old May 24, 2006 | 08:16 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">
so do i put a jack under the engine, remove all 3 mounts, and drop the tranny with anther jack?</TD></TR></TABLE>
yes. its clearly shown in the helms manual. you should get one.
Old May 24, 2006 | 10:52 AM
temp's Avatar
Default Re: Tranny mounts for dropping tranny, do i take out all 3 ? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
yes. its clearly shown in the helms manual. you should get one.</TD></TR></TABLE>
Old May 24, 2006 | 10:57 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: Tranny mounts for dropping tranny, do i take out all 3 ? (temp)
yea, taking a break, doing the rest tommrow.. what a pain, the psnger side axle won't pop out, gotta get a flatter bar or something, and there is 1 casing bolt above the axle, thats a real pita to get at.. so i think im gonna remove all the coolant lines and such.
should be able to get at it then, other than that its just dropping it.. shoulder is hurting a lot thow.. damm breaker bars
crx90421
Oct 8, 2009 10:40 PM
esean93
Oct 12, 2008 03:29 PM
ERIC!
Jun 26, 2005 04:11 PM
phantom_sol
Feb 24, 2004 09:45 AM
