um...did i buy a ex/si tranny?
i think when i still had my crx hf tranny(with a bad bearing) and im going 70 mph on the highway my rpms in fifth gear were about 1k rpms or so.
ever since i changed out my tranny im getting 3k rpms in 5th gear going 70 mph.
so did i get a ex/si tranny instead of an hf?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice a roni »</TD></TR><TR><TD CLASS="quote">i think when i still had my crx hf tranny(with a bad bearing) and im going 70 mph on the highway my rpms in fifth gear were about 1k rpms or so.
so did i get a ex/si tranny instead of an hf?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">ya, i get 60mph (100km/h) @ 3,000rpm. Due to slight variances in tire size, speedometer accuracy, id say you got an Si tranny for sure.</TD></TR></TABLE>
what's the code on your tranny? i need to know for one i just picked up.
from what i read i got the smaller bearing tranny and that would signify a dx, hf. but im getting 3000rpm at 70 mph...so thats confusing me. im running 185/65 or 60/13
but my civic ex runs at the same rpm and its only an inch bigger on the rim size. shouldnt make that much of a difference would it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice a roni »</TD></TR><TR><TD CLASS="quote">but my civic ex runs at the same rpm and its only an inch bigger on the rim size. shouldnt make that much of a difference would it?</TD></TR></TABLE>
Rim size doesn't matter, it's overall diameter including tire. 13 inch with 65 is just as wide as 14 with 55, adleast I think (crosses fingers that he can still talk to tire talk).
EDIT: **** i lied man, i must have left them in my apartment at school Sry
If you want new bushings I think i have a set sitting in my basement
PM me and i'll let them go real cheap
Tire sizes do not affect speedometer/tachometer reading ratios. They only affect actual ground speed vs. indicated speed.
You have a DX trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
You have a DX trans.</TD></TR></TABLE>
i am gonna have to agree. IIRC the HF axle wont even fit right into an Si trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">IIRC the HF axle wont even fit right into an Si trans</TD></TR></TABLE>
Yes it will. All '88-91 USDM axles are the same on the transmission end. The difference is at the hub end.
Yes it will. All '88-91 USDM axles are the same on the transmission end. The difference is at the hub end.</TD></TR></TABLE>
ah! thank you for the correction
is there any way to tell besides "what your rpms are at a given speed" and taking the transmission apart (the code on the tranny it self)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeaclearerskyxx »</TD></TR><TR><TD CLASS="quote">is there any way to tell besides "what your rpms are at a given speed" and taking the transmission apart (the code on the tranny it self)?</TD></TR></TABLE>
some of the older trannies dont have numbers on them, or they had stickers which, by now are mostly worn off.
Tire sizes do not affect speedometer/tachometer reading ratios. They only affect actual ground speed vs. indicated speed.</TD></TR></TABLE>
now that i think about it, you're right. smart ***
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeaclearerskyxx »</TD></TR><TR><TD CLASS="quote">well, if it did still have a sticker, which mine does, and it starts with "SL3", what tranny is that?</TD></TR></TABLE>
super laser 3?
super laser 3?
SL3 is usually a 91 DX transmission - the SL3 tag is on the top of the case - not on front like other L3s
Sounds like a DX/LX tranny to me.
