BAD NEWS
Old May 24, 2006 | 03:56 AM
Sir2egk's Avatar
Default BAD NEWS
i knew it was going to happen sooner or later and it did, new setup coming soon and its not going to be a stock block
car originaly made 646whp on bone stock motor at 26psi
http://media.putfile.com/Onix-blown-motor
Old May 24, 2006 | 04:51 AM
Hyaboosta's Avatar
Default Re: BAD NEWS (Sir2egk)
oh this is the k20/k24 stoopified car thats been all over the net. good luck man Im sure with a full build this cars gonna peg 800 easy.
Old May 24, 2006 | 05:27 AM
Turbo-charged's Avatar
Default Re: BAD NEWS (Hyaboosta)
oops! do you guys always dyno in the dark?
Old May 24, 2006 | 05:45 AM
MidShipCivic's Avatar
Default Re: BAD NEWS (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">oops! do you guys always dyno in the dark? </TD></TR></TABLE>
Camera doesnt do a good job at catching the light.
Old May 24, 2006 | 05:47 AM
99B16Si's Avatar
what let go? rod?
Old May 24, 2006 | 06:47 AM
HybridKOOP's Avatar
Default Re: (99B16Si)
Awesome! I couldn't believe it when Matt told me about your setup... that was impressive as **** while it lasted! Good luck on the new setup
Old May 24, 2006 | 06:52 AM
qfast817's Avatar
man that thing was a ****** beast, damn stan lost the wastegate o ring
Old May 24, 2006 | 08:42 AM
g2crx's Avatar
time for bigger and better
Old May 24, 2006 | 08:53 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: BAD NEWS (g2crx)
wow man, that car was a beast...
Old May 24, 2006 | 09:04 AM
mrDFWmechanic's Avatar
it was only a matter of time
Old May 24, 2006 | 09:47 AM
RonMexic07's Avatar
sux man.. im sure it will be back better than ever tho. GL man
Old May 24, 2006 | 09:53 AM
raiden571's Avatar
i noticed the vid mentioned something about testing different cams, care to elaborate which ones and what seemed to be better before she let go
Old May 24, 2006 | 10:52 AM
alopez84's Avatar
We all know it will be back bigger and better! Good job guys!
Old May 24, 2006 | 11:13 AM
Sir2egk's Avatar
Default Re: (raiden571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 &raquo;</TD></TR><TR><TD CLASS="quote">i noticed the vid mentioned something about testing different cams, care to elaborate which ones and what seemed to be better before she let go</TD></TR></TABLE>
motor was completely stock, i was going to put my IPS KT1 cams but then i didnt want to put it on till the build, we were just seeing how much she can take, but she didnt make it past 481 @ 20psi
what happened was that in one run, a vacuum line poped off and since its a 20psi spring, it spiked to 30psi in no time and i have a pea size hole on the block, i havent pulled the motor out yet, i will most likely do it today and post up some pics for yall
Old May 24, 2006 | 11:20 AM
HybridKOOP's Avatar
Default Re: (Sir2egk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sir2egk &raquo;</TD></TR><TR><TD CLASS="quote">
what happened was that in one run, a vacuum line poped off and since its a 20psi spring, it spiked to 30psi in no time and i have a pea size hole on the block, i havent pulled the motor out yet, i will most likely do it today and post up some pics for yall</TD></TR></TABLE>
I was gonna say, it seemed to happen at real low RPM, so I assumed it was a spike or a fuel issue as well.
OMG Its a Honda
Apr 21, 2006 08:39 AM
blitz118
Jan 24, 2006 07:54 PM
TurboJesse
Oct 3, 2005 07:26 AM
