BAD NEWS
i knew it was going to happen sooner or later and it did, new setup coming soon and its not going to be a stock block
car originaly made 646whp on bone stock motor at 26psi
http://media.putfile.com/Onix-blown-motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">oops! do you guys always dyno in the dark?
Camera doesnt do a good job at catching the light.
</TD></TR></TABLE>Camera doesnt do a good job at catching the light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raiden571 »</TD></TR><TR><TD CLASS="quote">i noticed the vid mentioned something about testing different cams, care to elaborate which ones and what seemed to be better before she let go</TD></TR></TABLE>
motor was completely stock, i was going to put my IPS KT1 cams but then i didnt want to put it on till the build, we were just seeing how much she can take, but she didnt make it past 481 @ 20psi
what happened was that in one run, a vacuum line poped off and since its a 20psi spring, it spiked to 30psi in no time and i have a pea size hole on the block, i havent pulled the motor out yet, i will most likely do it today and post up some pics for yall
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sir2egk »</TD></TR><TR><TD CLASS="quote">
what happened was that in one run, a vacuum line poped off and since its a 20psi spring, it spiked to 30psi in no time and i have a pea size hole on the block, i havent pulled the motor out yet, i will most likely do it today and post up some pics for yall</TD></TR></TABLE>
I was gonna say, it seemed to happen at real low RPM, so I assumed it was a spike or a fuel issue as well.
