crx 84 ls (1.5 i was told) Wont idle after it has warmed up.
I just picked up this 84 rex a few days ago. So far it's running fine. I haven't had any real time to check it out tho. But what might cause it to die? When it's cold I can drive it around and stop at a light and have no worries. when it's cold it's about 2000 rpms (kind of high?) But after about 10 mins of driving and I come to a stop or put in the clutch the car wont keep an idle. Any help would be great. Thanks
-lM-
Modified by EnSAn at 8:49 AM 5/24/2006
-lM-
Screw you guys, I'm... going... home.
What is an 84 CRX ls? Does it have a B18A/B swap in it or something?
Go to http://www.redpepperracing.com and read the FAQ, read the shop manual at the top, and then ask questions in the Tech --> Carbs section. It sounds like either your warm idle is set too low or you have a vacuum leak in your brake booster. Can you be any more specific about exactly when it happens?
Race Egr
Apr 3, 2004 02:20 PM
So there is no LS my mistake. sorry for the confusion.
