questions about trailing arm bushings and replacement
Old Apr 12, 2002 | 10:04 PM
B16ED4G's Avatar
Default questions about trailing arm bushings and replacement
I know that this question has been asked thousands of times, and I did try to search, but didn't find a straight answer.
I have the energy suspension complete bushing kit along with the trailing arm bushing kit, I know that you are supposed to use the stock hardware with the T/A bushings. My question is what method have you guys used to remove the old bushing and install the new ones? It appears that the entire trailing arm has to be removed from the vehicle. is this correct? I hate to open the brake system and fool with that damn E brake cable if i don't have to. I have a press to get the new bushing in, is there any easier way?? any tips on this topic would be greatly appreciated
Thanks
Chris
Old Apr 13, 2002 | 06:45 AM
B16ED4G's Avatar
Default Re: questions about trailing arm bushings and replacement (B16ED4G)
no one has done this??
Old Apr 13, 2002 | 07:12 AM
Charlie Moua's Avatar
damn i would like some info in this too. i'm sure somebody has had it done to there car .
Old Apr 13, 2002 | 08:31 AM
blunty's Avatar
Yeah I need to do this too. From the research I've come across, you either blow torch the rubber out of there or somehow remove as much of the rubber as you can and then take a wire brush attached to a drill and clean the rubber out. Then drive the new bushings in by coating the bushings well with grease. However, I was thinking that I might be able to take a rubber mallet or something and bang it in there somehow. Here's a link I found that might be helpful. Go down 2/3s of the page and it gets into the trailing arm bushing.
http://overboost.com/story.asp?id=426
Please keep me posted on the project. B16ED4G, where did you get the trailing arm bushings and how much?
Old Apr 14, 2002 | 05:07 AM
7PSI CRX's Avatar
Here's the way they say to do it......
It's not necessary to remove the arm from the car.
Old Apr 14, 2002 | 11:56 PM
KKHybridCRX's Avatar
I just bought the prothane rear trailing arm bushing kit. It comes with all the hardware so you just press out the old ones, and press in the new ones.
Old Apr 15, 2002 | 08:43 AM
Driven's Avatar
Default Re: questions about trailing arm bushings and replacement (KKHybridCRX)
To all those who wanted to save $100 and spend 4 more hrs on this, have a worse set of bushings, and nto have the adjustability the prothanes have
Don't bother with the ES bushings... you'll be cursing the day you bought them. Just get the prothanes
Old Apr 15, 2002 | 10:16 AM
blunty's Avatar
Default Re: questions about trailing arm bushings and replacement (7PSI CRX)
7PSI CRX, have you done this install or are you just posting the instructions? If so, what are your thoughts on the ES bushings. They're hella cheaper and I wouldn't need to have them pressed in. My Si is stock anyways, I just need to replace my shot stocky ones.
[Modified by blunty, 8:37 AM 4/17/2002]
Old May 1, 2003 | 07:55 AM
ragejed's Avatar
Default Re: questions about trailing arm bushings and replacement (Driven)
Originally Posted by Driven
<BLOCKQUOTE>quote:<HR>I just bought the prothane rear trailing arm bushing kit. It comes with all the hardware so you just press out the old ones, and press in the new ones.<HR></BLOCKQUOTE>
<IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0">
<IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthdown.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthdown.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthdown.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthdown.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthdown.gif" BORDER="0"> <IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthdown.gif" BORDER="0">
A worse setof bushings? thats a good one.
I got the ES ones. Nothing wrong with them. You gotta be a moron not to save 100 bux!. I had the extra time, so why not?
Old May 1, 2003 | 08:12 AM
Steve91's Avatar
I installed the ES T/A bushings on my crx. You really need to remove the trailing arm to do it right. The old bushings is a bitch to remove. The easiest way is to take it to a muffler shop and have them melt out as much of the old bushing with a torch. I then cleaned the pin on a wire wheel grinder. The last step was using a 1/4 drive dremel with sanding cartriges to remove all rubber on the shell.
Old May 1, 2003 | 12:23 PM
7PSI CRX's Avatar
Default Re: questions about trailing arm bushings and replacement (Steve91)
Just a propane torch and a screwdriver to push the crap out.
Heat the metal around the bushing, don't set the bushing on fire!
Get it hot enough, and it'll slide right out.
Then heat it a little more and wipe it with a rag and it'll be clean.
I have a '91...Rear disc brakes, did not mess with the hydraulics at all.
Clean up the pin with a razor/sandpaper.
Reinstall.
Easy.
*NOTE* take notice of which side of the pin faces the outside of the car. One side has a hole, the other side a slot.
Yes, I removed the whole trailing arm. Just a matter of the caliper bracket and the E-brake cable. (for me)
I also drilled a few small holes in the pin and drilled and tapped a 1/8 NPT thread and added a grease fitting.
(The pin is hollow)
As a matter of fact, I just greased them Monday.
I've never seen the prothanes, but the ES ones are 10000X better than the broken stock ones that were in there to begin with.
Old May 1, 2003 | 12:27 PM
7PSI CRX's Avatar
This came alive from a year ago, eh?
Old May 1, 2003 | 12:41 PM
dester223's Avatar
Good information!!!
Old May 1, 2003 | 01:04 PM
ragejed's Avatar
Default Re: (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">This came alive from a year ago, eh?</TD></TR></TABLE>
Ya...i searched
But ya..Dont set it on fire? crap...i did. I had cut the put out already, then took the torch..poored mobil1 on the bushing..then up in flames she went
Old May 1, 2003 | 01:15 PM
Steve91's Avatar
Fire is half the fun!
Old May 1, 2003 | 01:29 PM
ragejed's Avatar
It was
98civdx
45
Mar 20, 2013 05:50 PM
aimbot
Jan 4, 2008 04:02 AM
in1accord
Aug 31, 2007 04:32 AM
chatham
May 20, 2006 10:18 PM
teg94
Aug 24, 2001 04:33 AM
