eziest way to install autometer water temp gauge
whats the easiest way to do this? do i have to tap the block? everything is already installed in my car and all and i dont want to have to do that. someone have some input on this?
Finally, I put the autometer sensor drilled into the Water Outlet Cover aka "water neck " and everything is fine. The water outlet cover is at the top of engine block where its connect the upper radiator hose and the engine.
FYI.. Water outlet cover part number: 19315P30J01 ~$13.00
thank you for the help. so the install didnt take too much i take it?also, since i am running an obd1 computer would the CEL turn on in my case. its and obd2 engine but i did the jumper conversion to obd 1 and run a p28 ecu now
[Modified by gsr98vtec, 12:18 PM 4/13/2002]
