yes ive searched but i have a sunroof question
Old May 23, 2006 | 04:38 PM
viciousvisionslarry's Avatar
Default yes ive searched but i have a sunroof question
my 89 si sunroof doesnt open or close via the switch it does open and close via allen wrench i pulled the headliner down and put power to the motor with jumper wires and to motor works so i have no idea what to do next?
Old May 23, 2006 | 04:44 PM
wood 1's Avatar
Default Re: yes ive searched but i have a sunroof question (viciousvisionslarry)
Take the switch apart and clean or replace it. You have checked the fuse?
Old May 23, 2006 | 04:45 PM
Default Re: yes ive searched but i have a sunroof question (wood 1)
yes ive checked the fuse
Old May 23, 2006 | 05:10 PM
sirrvanna's Avatar
it means, ur sunroof needs a new owners
Old May 23, 2006 | 05:19 PM
Default Re: yes ive searched but i have a sunroof question (sirrvanna)
dont hate me cause i bought an 89 si with 77,000 and no rust for $600
Old May 23, 2006 | 05:41 PM
sirrvanna's Avatar
holy ****, i wish i had that deal
Old May 23, 2006 | 05:43 PM
pulled the switch apart everything apears to be in good working order
Old May 23, 2006 | 05:53 PM
roterx7's Avatar
jus get a new switch at the junkyard or something. or buy one from ebay
Old May 23, 2006 | 06:02 PM
Default Re: (roterx7)
i tried to jump the circuit out but not sure if im doing it right i think im chasing my tail here
Old May 23, 2006 | 07:48 PM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood 1 &raquo;</TD></TR><TR><TD CLASS="quote">Take the switch apart and clean or replace it. You have checked the fuse?</TD></TR></TABLE>
Ding , Ding Ding !!!
We have a winner folks !
I'm with this guy.
Old May 23, 2006 | 07:55 PM
firme ef8's Avatar
Default Re: yes ive searched but i have a sunroof question (Rex-Si)
yea replace the switch. had the same problem and that fixed it.
Old May 24, 2006 | 10:56 AM
Default Re: yes ive searched but i have a sunroof question (xownsx)
i think the switch is fine i ohmed it out and appears to be fine does anyone have the wiring diagram
Old May 24, 2006 | 11:22 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
from the FAQ section:
http://mirror.rivendel.nu/crxc...f.pdf
*requires adobe acrobat reader
Old May 24, 2006 | 11:44 AM
Mixelplix's Avatar
Default Re: yes ive searched but i have a sunroof question (88DXCRX)
There's a clutch on the motor.
Assuming the motor turns when you hit the switch, you need to tighten the clutch.
Do a google search for "crx factory service manual" there's a section in the FSM on how to tighten the sunroof clutch.
-Des!
Old May 24, 2006 | 12:45 PM
Default Re: yes ive searched but i have a sunroof question (Mixelplix)
ok let me be a little more clear when i unplugged the sunroof at the motor and put power right to the motor and it opened and closed. i pulled the switch apart everything appears to be fine.either im not getting power to the switch or theres a break in the wire.i just want wire colors going into the plug
Old May 24, 2006 | 12:54 PM
ILcrxsi1's Avatar
I tell doctors what to do
the switch will look fine and be garbage, it's the problem 99% of the time
Old May 24, 2006 | 01:20 PM
Default Re: yes ive searched but i have a sunroof question (ILcrxsi1)
i tested it at work on a volt ohm meter
Old May 24, 2006 | 06:11 PM
'90crxSI's Avatar
check for voltage on the plug for the motor...contacts could be dirty.
My switch was also bad, but I cleaned the contacts on the inside real good and made sure the touched when the switch was pushed and that fixed my problem as well...hope its something that simple with yours!
Old May 24, 2006 | 06:24 PM
88DXCRX's Avatar
See quote below:
Modified by 88DXCRX at 1:47 PM 5/25/2006
Old May 24, 2006 | 06:38 PM
see thats what i needed ill let u know how i make out
Old May 25, 2006 | 07:41 AM
jdmEF8racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Click on the pic and after it loads,click again for full size:
**** man where did you get that?
i need that same thing, my sunroofs got problems too
Old May 25, 2006 | 10:47 AM
88DXCRX's Avatar
Helms factory service manual and a scanner...
Old May 25, 2006 | 11:49 AM
Its me DUB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">Helms factory service manual and a scanner... </TD></TR></TABLE>
88DXCRX = Honda Tech Helms hook-up
Old May 26, 2006 | 03:19 AM
alright guys thanks for al your help it was the relay
TSME
Apr 19, 2014 08:19 AM
pacurcouch
Nov 11, 2013 06:26 PM
Dr.Fixit
Sep 20, 2013 04:42 PM
Hondasalesman
Mar 27, 2009 09:11 AM
assassinACE12
Jan 30, 2008 08:42 PM
