i need some help with my headlights
Old May 23, 2006 | 01:50 PM
01-0720's Avatar
Default i need some help with my headlights
ok so i got a jdm itr hid front end, i was having some trouble getting the heaglights wired up
i found out i need to put a relay in
now my question is where does this relay go, does it go between the us wireing and the jdm wireing coming off the headlights or does it go somewhere else
id really apprecit if some could let me know where to put this relay in
thanks alot
eric
Old May 23, 2006 | 03:29 PM
94rs-turbo's Avatar
relay for what?
Old May 23, 2006 | 04:40 PM
01-0720's Avatar
Default Re: (94rs-turbo)
for the hid's
Old May 23, 2006 | 07:52 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">relay for what?</TD></TR></TABLE>
For the foglights. He'll need a fuse for it also.
Old May 23, 2006 | 08:27 PM
Spids5's Avatar
Don't judge or question
Default Re: (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">for the hid's</TD></TR></TABLE>
You don't need a relay for the hids. You only need one for the foglights, there is a really good write-up on here but I'm to lazy to search for it.
Old May 23, 2006 | 09:53 PM
Kicker773's Avatar
Default Re: (spids5)
yep foglights
Old May 24, 2006 | 04:55 AM
01-0720's Avatar
Default Re: (Kicker773)
ooo im a dumbass, i just went back and looked at the picture i had and sure enough it was pointing to the foglights
but now im confused as to why my hids, and high beams dont work, i followed the wireing diagram on mase's post, and they both still dont work
any ideas of what i should check?
Old May 24, 2006 | 11:11 AM
01-0720's Avatar
ill give a hundred dollars cash money, and all the beer and pizza you can consume to the person who can get my hids/high beams, and turn signals to work like oem
Old May 24, 2006 | 11:24 AM
Spids5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">ill give a hundred dollars cash money, and all the beer and pizza you can consume to the person who can get my hids/high beams, and turn signals to work like oem</TD></TR></TABLE>
If I was in md I would help you out. When I get off work I will check which wires went where because I remember having a problem with the wiring when I did mine. Btw, which write-up did you use?
Old May 24, 2006 | 07:16 PM
01-0720's Avatar
i went by mases and this one
im thinking it might be a ground or a fuse, ima check both tommarow, only reason i whould ask someone to do it, is i work weird hours, and when i get off i usually only have like an hour or so to work on the car untill its dark, and thats not enough time
iskate2
Apr 8, 2007 07:10 PM
elmanning
Jun 14, 2005 08:59 PM
Tonydalude
Nov 18, 2004 02:14 PM
bustah49
Aug 23, 2004 12:21 PM
