HELP! Are my compression Numbers Good?
Old May 23, 2006 | 10:08 AM
vodkas22's Avatar
Default HELP! Are my compression Numbers Good?
I was just wondering what kind of numbers I should be running for my set up. I have an LS-Vtec set up with high compression pistons (12:1 compression). I am using the stock LS three layer head gasket with the milled type R head of .01 mm. I checked my compression and it is about 210 across all four cylinders. Does that sound about right? Any suggestions would help. Thanks!
Old May 23, 2006 | 10:14 AM
Natural Aspirations's Avatar
They look a lil low to me for that C/R Depends on what cams your using.
Old May 23, 2006 | 10:37 AM
HYBRID FREAK's Avatar
My ls/vtec has b16 pistons and i read 270 psi across all four.
Old May 28, 2006 | 08:34 PM
Quick99's Avatar
Default Re: HELP! Are my compression Numbers Good? (vodkas22)
i have a lsv with p30's in it, its around the 12:1cr mark, compression tested all 4 cylinders @ 270-275.
Old May 29, 2006 | 05:21 AM
D-Rob's Avatar
Default Re: HELP! Are my compression Numbers Good? (Quick99)
LSVTEC with 0.25 OS P30's here, and...
280-285psi across all cylinders.
Old May 29, 2006 | 06:35 AM
marcin's Avatar
Default Re: HELP! Are my compression Numbers Good? (D-Rob)
none of you guys listed what cams your using...and thats going to play a BIG part in it.
m.
Old May 29, 2006 | 08:33 AM
D-Rob's Avatar
Default Re: HELP! Are my compression Numbers Good? (marcin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcin &raquo;</TD></TR><TR><TD CLASS="quote">none of you guys listed what cams your using...and thats going to play a BIG part in it.
m.</TD></TR></TABLE>
Skunk2 Pro2+'s chief.
Old May 29, 2006 | 09:07 AM
vodkas22's Avatar
Thanks guys...that helps me a lot...any others would be helpful
Old May 29, 2006 | 06:44 PM
Quick99's Avatar
...sorry i'm using BloxA cams
Old May 30, 2006 | 10:41 AM
Mike@K-Tuned's Avatar
Don't worry too much about static compression test numbers. It is a good idea to check compression numbers every now and again to ensure all cylinders read evenly. The more duration a set of cams have, will most likely result in lower static compression. The compression gauge is a good tool to check the health of the bottom-end or more basically to see if the rings are sealing properly. Huge static compression numbers will have very little effect on what kind of power you're engine will make. Check out the power other honda-tech members are making with very simple 1.8L engines. I'll post the link below.
Modified by EGgsrAM at 4:03 PM 5/30/2006
Old May 30, 2006 | 03:09 PM
Default Re: HELP! Are my compression Numbers Good? (EGgsrAM)
Here you go. Some of these 1.8's are very impressive https://honda-tech.com/zerothread?id=1263436
Also please tell us what pistons and cams you are using. Also are you using an expensive accurate compression tester or some cheapy dime store tester.
Old May 30, 2006 | 08:11 PM
vodkas22's Avatar
From what the guy I bought the motor from, he told me I have CP 81.5mm 12:1 compression pistons, with some kind of stage 3 cams, he's not sure what kind though. The compression tester is a 30 dollar screw in one I bought from bumper to bumper.
Old May 30, 2006 | 08:37 PM
92TypeR's Avatar
FSAE
The actual number you shouldn't worry about.
It is the variance between the numbers that is the concern. You should be within &lt;5% of every cylinder.
Just swapping cams can change static compression as much as 40psi. Not to mention different gauges and testers read differently. I've seen a 150psi difference just by switching brands.
skippy33
Feb 7, 2021 05:34 PM
pootie.teng
Jun 24, 2005 06:19 PM
CALM_AS_A_BOMB
Mar 14, 2005 05:34 AM
MysteryWagon
Feb 11, 2005 09:18 AM
Notaverage
Dec 1, 2003 04:53 PM
