4th Gen SUnroof Removal?
Old May 23, 2006 | 08:38 AM
prelude96h23a's Avatar
Default 4th Gen SUnroof Removal?
i read the Chiltons and other manuals for my 1996 prelude but i cannot figure out how to remove the sunroof. i want to take it apart to sand, paint nad put new rubber around the panel.
Can anyone help me with my search? i have looked at most of the search topics and General information about this topic but i cannot find any information.
thank you for reading my plea.
Old May 23, 2006 | 12:10 PM
soundbomber's Avatar
Default Re: 4th Gen SUnroof Removal? (prelude96h23a)
you have to take off the roofliner, and from there, you'll need to unbolt the frame of the sunroof and let it drop down. it's a bitch.
Old May 23, 2006 | 01:13 PM
hp92lude's Avatar
Default Re: 4th Gen SUnroof Removal? (soundbomber)
i may be wrong but i was under the impression once you get the small roofliner piece on the moonroof itself (mine fell off a while ago), you just take 4 bolts out and its done...?
i need to know also since im painting my car and i have to get the moonroof out as well.
Old May 23, 2006 | 01:38 PM
Default Re: 4th Gen SUnroof Removal? (hp92lude)
the bracket goes all the way to the back of the roof..well i took mine out with the motor and frame altogether
Old May 23, 2006 | 01:54 PM
cifer6425's Avatar
my 94 had two screws up front that held the liner in place, 3 screws in the back with two nuts/bolts on the outer side. remove the metal piece from the back. slide out liner. remove 4 nuts each side of sunroof, pick up and carry off.
fairly simple to do.
good luck
Old May 23, 2006 | 06:42 PM
SnlpeR's Avatar
damn you guys are doing it the hard way
pull the rubber/velvet molding from the roof opening from the inside
slide the sunroof back till the screws line up with the notches on the metal frame
unscrew those 2 screws and pry the sunroof interior panel down
pull it out from the opening in the rear
then unbolt the 4 corners of the panel
Old May 23, 2006 | 10:19 PM
Hawkze_2.3's Avatar
Default Re: 4th Gen SUnroof Removal? (apeng09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apeng09 &raquo;</TD></TR><TR><TD CLASS="quote">it's pretty disgusting knowing that there is 56 lbs of sunroof crap up there. if i had the money, i'd def get the cf sunroof plug.</TD></TR></TABLE>
Where'd you get 56 from?, I only came up with 43 lbs including the interior peices.
Old May 25, 2006 | 07:34 AM
Default Re: 4th Gen SUnroof Removal? (SnlpeR)
i tried to simply take off the sun roof with out takign off the roof panel but it didnt really work. i mean ill try taking off the rubber that wraps around the sunroof panel and see how it works. the body shop guy i talked to said i will most likely have to remove the roof panel.
where do i get new rubber to wrap around the panel? i have rust becasue i do not have an affective drain , the water simply sits on the corners of the panel.
y2kferari
14
Oct 13, 2008 05:25 PM
SunnyTO
Aug 17, 2007 09:58 PM
budget
Jul 25, 2006 08:26 AM
Jer'rome
Honda Civic (2001 - 2005)
May 10, 2006 12:52 PM
RusBear
Dec 16, 2005 01:34 AM
