ls tranny question
Old May 23, 2006 | 08:03 AM
boostedSI90hatch's Avatar
Banned
Default ls tranny question
i just finished my ls swap into my 90 civic and now when the tranny is in gear it feels like it isnt, i can move the shifter all around like its out of gear. i pulled the tranny apart before the install and everything looked great. im thinking worn shift link bushings or something?
this is a YS1 tranny impretty sure thats a 92-93 GSR just incase that has something to do with it.
if anyone has had this problem please post up.
thanks
Hooker
Old May 23, 2006 | 08:21 AM
Banned
Default Re: ls tranny question (boostedSI90hatch)
bump for info
Old May 23, 2006 | 08:34 AM
Banned
bump
Old May 23, 2006 | 08:36 AM
ludesrv's Avatar
I thought YS1 was a B16A with LSD tranny?
Either way, for the price of new bushings you should just replace them for the fell. I doubt it's the tranny that's fucked. I've only seen 1 tranny lock itself in a gear, D series tranny blew up in 2nd gear, happened twice to the same driver, that should tell you something about the driver haha.
Old May 23, 2006 | 08:40 AM
Banned
Default Re: (ludesrv)
mabey that would be nice seeing i payed 100$ and a shi* amp for it!!!!!!
Old May 23, 2006 | 09:46 AM
Suck my DX's Avatar
Default Re: (boostedSI90hatch)
replece ur shifter bushing...mine did the same **** until i replaced it...it will feel like a new car again...
u got lsd?
Old May 23, 2006 | 10:07 AM
Gearspeed-Performance's Avatar
Default Re: (Suck my DX)
The YS-1 was available in the US as an LS and a GSR model
It also was available in Japan as a XSi Integra in LSD and non-LSD
I would disconnect the linkage and put the car into gear directly at the transmission and make sure that it selects each gear. If it does I would look past the internals of the transmission and towards the linkage and possibly the clutch.
Old May 23, 2006 | 10:33 AM
Suck my DX's Avatar
Default Re: (GearSpeedEF7)
check the little things first...its a rubber bushing thats exposed to the elements...over 16 years its gonna dry out and fatigue...like i said mine did the exact same thing...it had so much play when it was in gear it started to bother me with the daily driving...i used the es bushing and a generic short shifter and it felt soo much better
Old May 24, 2006 | 05:24 AM
Banned
ok thanks yea im not quite sure if its got an lsd or not i friggin hope!!!
Old May 24, 2006 | 12:29 PM
Suck my DX's Avatar
look at your differential...if it is a hole through it its lsd...but if their is a piece of metal in there than its not...probably doesnt make sense the way i said it...but look in their u will immediately know what im talkin about
Old May 24, 2006 | 12:33 PM
Loserkidwac's Avatar
Ok...I'm just guessing but you cut and welded your linkage from a teg or you hav used linkage??? if so i know your problem, I've bought 2 2g tegs that had this problem now, feels like its in N in every gear but drives fine, the joints in the linkage are worn out , you need some new linkage or atleast the end that goes on the tranny...HTH
Old May 24, 2006 | 12:34 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">u got lsd?</TD></TR></TABLE>
h-t forums are not places for drug deals!
lacking vtec
Mar 29, 2007 03:29 AM
Honda Bull
Oct 22, 2005 02:11 PM
DsBananas94LS
Nov 1, 2004 05:22 PM
