What Flange do I use T3, T4, T3/T4?
Old May 23, 2006 | 07:53 AM
saywhat's Avatar
Default What Flange do I use T3, T4, T3/T4?
I am building a junk yard turbo setup and I picked up a turbo from a 96 saab 900 turbo, the problem is I started making a manifold, and the only thing I need is the flange for the turbo, I bought a t3/t4 flange (ebay) and it doesn't fit, it is like a half inch too big all around, does anyone know what flange I should be searching for, I don't think it is a common one. TIA
Old May 23, 2006 | 08:16 AM
I Have an STD's Avatar
wrenchin'
Default Re: What Flange do I use T3, T4, T3/T4? (saywhat)
uhh.... u cant buy a T3/T4 flange. its either one or the other. post a pic of it. your probably bought a T4 flange and u need a T3 flange
Modified by I Have an STD at 4:06 PM 5/23/2006
Old May 23, 2006 | 08:40 AM
spiceisler's Avatar
Default Re: What Flange do I use T3, T4, T3/T4? (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">uhh.... i cant buy a T3/T4 flange. its either one or the other. post a pic of it. your probably bought a T4 flange and u need a T3 flange</TD></TR></TABLE>
Sure you can................................... BMC race: (taken from their site)
$20
Old May 23, 2006 | 09:30 AM
saywhat's Avatar
Default Re: What Flange do I use T3, T4, T3/T4? (spiceisler)
That looks like exactly what I need only not threaded, can you throw me a link to their site.
Old May 23, 2006 | 09:40 AM
RCautoworks's Avatar
http://www.bmcrace.com
Tell him I sent you
Old May 23, 2006 | 11:36 AM
dpetro1's Avatar
what he meant was that t3/t4 hybrid turbos dont have their own flange, they use a t3 turbine so you need a t3 flange. the bmc flange posted is a combo flange that is drilled for both. its not specific to t3/t4 turbos, it can be used for t3 OR t4 turbines.
to the original poster, your turbo should have a t3 flange. post up some pics of the turbo and the flange so we can help you better.
Old May 23, 2006 | 12:05 PM
wrenchin'
Default Re: What Flange do I use T3, T4, T3/T4? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">what he meant was that t3/t4 hybrid turbos dont have their own flange, they use a t3 turbine so you need a t3 flange. the bmc flange posted is a combo flange that is drilled for both. its not specific to t3/t4 turbos, it can be used for t3 OR t4 turbines.
to the original poster, your turbo should have a t3 flange. post up some pics of the turbo and the flange so we can help you better. </TD></TR></TABLE>
thank you, yes, thats what i meant
rx7_
Sep 9, 2009 02:58 PM
d16civic111
Sep 14, 2006 04:57 PM
RACEPAK
Nov 25, 2005 12:34 PM
