Rough idle after beating on car, Stock ecu, D16z6, Swap
Old May 23, 2006 | 05:44 AM
NJcoupe's Avatar
Default Rough idle after beating on car, Stock ecu, D16z6, Swap
tried in 92-00 forum couldn't get anything.
92 cx hatch, d16z6 freshly rebuilt, new rings, bearings, zex 59300 cam, Stock p28, new cap, new rotor, new wires, intake,header, stock exhaust.
Car runs rediculously rich, and it idles and runs like **** after its beat on, seems like it appears to be miss-firing.
Car also gets horrrrrible gas milage, gets around 200 miles per tank in, without beating on it.
Old May 23, 2006 | 05:47 AM
trickeng's Avatar
Default Re: Rough idle after beating on car, Stock ecu, D16z6, Swap (dxcoupe.)
most likely the car is loading up after you beat on it and it has to burn off all the extra fuel in the cylinder before it can idle normal.
or its the piston return springs.
chargerbandit
May 26, 2018 12:32 PM
jaycorolla
18
Aug 30, 2011 04:07 PM
danewjdmrice
Apr 8, 2009 11:45 PM
swifty4u
Jul 5, 2006 07:45 AM
92civeg
Feb 19, 2006 05:55 PM
