HELP PLEASE!!!! remote start and starter disable on 92 civic vx......
Vehicle = 92 Honda Civic Hatch VX 5speed =D
Alarm = Autopage rs-725LCD.... http://www.autopageusa.com
Okay...the last thing i need to hook up is the "remote start and starter disable"...i think i got everything else done just those 2 left....I need help finding the rest of the wires from the alarm to hook up to the vehicle wires....here are the wires from the alarm that arent connected to the car yet....i need to know what wires i can use and what i cant use...also need the wires colors from vehicle.
"from alarm" ..#H10 20 Pin Connector..
1. white/black (-) negative safety shut down input for hood pin switch
2. white/Violet (+) Positive Safety shut down input for brake switch
3. Black/White (-) Neutral Safety Switch Input.
4. blue - zone 2 instant trigger ground input
5. white/green (-)diesel wait to start input
7. violet - zone 3 positive door pin trigger input
8. white/blue (-) Instant Start and Turn Off input
10. blue/black - (-) 200 ma accessory 2 output
11. yellow - (-) 200ma ignition 3 control output
14. pink - (-) 200ma programmable output, 2 steps door unlock output or start status output
16. black/green -(-) 200ma progrmmable output, 1. channel 4 programmable output
i know this alarm is not for manual cars but i already know how to by pass the clutch already..im not sure where to hook up the "Black/White wire - Neutral Safety Switch input" since i dont think i have that on a 5speed..
please help!!! if u can..thanks..!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRGDC »</TD></TR><TR><TD CLASS="quote">It is dangerous to remote start a 5 speed you know that right??? </TD></TR></TABLE>
yes..i truly understand that....!!!...help???
You would normally use the first four. Unfortunately, your 5 speed doesn't have a neutral safety switch. Also, it isn't going to start with the clutch out. Maybe you should do a manual to auto conversion. I would, if remote start was so important to me that I'd risk the car and possibly human lives just to have it.
On HT, people wont tell you **** unless they feel like it. Maybe they'd feel like it if you explained how you are going to make the car safe. Or you could just try searching. There's probably 20 posts full of flames and in 2-3 of those you will find your answer.
If I were to give you the answer while on the clock, I could be fired.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">You would normally use the first four. Unfortunately, your 5 speed doesn't have a neutral safety switch. Also, it isn't going to start with the clutch out. Maybe you should do a manual to auto conversion. I would, if remote start was so important to me that I'd risk the car and possibly human lives just to have it.
If I were to give you the answer while on the clock, I could be fired.</TD></TR></TABLE>
actually you can remote start without pressin the clutch down. all you have to do is ground out the clutch.
hook up the first 4 wires...
1. if you hook up a hood pin switch (just be aware that switches tend to break or bend and go bad) so if you hook it up and later down the road it doesn't remote start check this pin switch.
2. hook it up to your brake pedal switch
3. optional...either ground it or hook it up to a toggle switch with one end going to this wire and the other end ground...allows you to disable rem start (for times you're taking it to a shop and you don't want them to accidently remote start the vehicle)
4. hook up to the hatch door pin, i can't remember if this pin is common with your door pins or not, if it's not hook it up to the hatch door pin wire. if it is common there's no need to hook this wire up.
you can use the status output wire from the rem start to ground the clutch wire found above the clutch pedal to get it to rem start...just remember to never leave you car in gear!!!!
Mrnieves98
Audio / Security / Video
Jul 10, 2016 01:04 PM
jayceng90
12
Jan 9, 2012 03:12 AM
IT LBS
26
Nov 11, 2008 04:06 PM
intezn
Aug 6, 2003 05:39 AM
