Torn between 2 VIPER ALARMS............HELP me choose one!
Old May 22, 2006 | 08:39 PM
thrty8street's Avatar
Default Torn between 2 VIPER ALARMS............HELP me choose one!
Car: Acura RSX-S
(2) alarms are :
1. Viper 5000
2. Viper 791xv
Im not using remote start so that doesnt matter to me. I plan to get a Backup Module 520T for either alarm. I also already have a new audio sensor 506t which my friend gave me for free.
The 5000 has 2 sensor ports while the 791xv only has one. The 5000 needs a hoodpin switch while the 791 already has one. Im having a hard time deciding.
-Whats better, an internal or external shock sensor?
-What sensors should I add??
I was looking at this website which I think is made by suspendedhatch.
http://www.vsracing.net/~suspended/
Old May 22, 2006 | 09:33 PM
94_DC4's Avatar
Default Re: Torn between 2 VIPER ALARMS............HELP me choose one! (thrty8street)
I would go with the 791xv cause of all the aux outpus which give you more options if you get creative. I think the 791xv is the best alarm on the market, but that is my personal opinion.
Old May 22, 2006 | 09:41 PM
Flatland2D's Avatar
Hoodpins switches are really cheap so that shouldn't be much of an issue here. You'll probably want an extra one for your trunk anyways.
I'm no alarm expert so I can't comment if internal or external shock sensors are better.
As far as adding sensors, I think the general consensus is that the AU94T radar proximity sensor (as mentioned on suspended's website) is probably the best one. I plan on getting one for my upcoming alarm install.
Don't mean to confuse you any more, but you may want to throw the Compustar 2WSS alarm into your decision. I had been planning on ordering a Viper 5000 for a while but changed my mind to the 2WSS. With FM spread spectrum communication, the range is supposed to be unbeatable. It's advertised as 6,000ft (1.25 miles), but I've read of people getting a least a few thousand feet from it in close to ideal circumstances. I believe the Viper alarms are only advertised at 1/4 mile.
Old May 23, 2006 | 06:16 AM
B18C_EJ8's Avatar
Definitely go with the 791 if you can swing it... Extra outputs are really nice for controlling lights and other accessories from the remote. Simple relays are required to make them work though...
Old May 23, 2006 | 04:28 PM
Default Re: (B18C_EJ8)
anyone else???
Old May 23, 2006 | 09:14 PM
bpr0422's Avatar
Default Re: (thrty8street)
viper 5000
i have one, not installed yet.. still waiting on the spools of wiring, door lock actuators, relays, etc..
but getting ready to install it... with other wires, for amps, and speakers...
if you don't need the remote start, just get the 5000
the sensor ports are not a problem, you can easily wire up more than one sensor to a port...
Things you should add: tilt/motion sensor, mini peizo sirens, and the crimeguard(crutchfeild) proximity sensor....
i'll post my alarm install up, when i get to it.. though i won't post everything.. cause i am doing a "custom" creative install...
Old May 24, 2006 | 09:52 AM
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">viper 5000
thanks! thats the answer I was looking for
Old May 24, 2006 | 06:31 PM
JSPECSIR's Avatar
since this is a double post check your other one. and a 5000 has just as many outputs as a 791.
Old May 24, 2006 | 07:54 PM
Default Re: (5THGENSI)
Just ordered the Viper 5000.
Can anyone recomend a good place to have my alarm installed in MD???
VTECROAR96typeR
Audio / Security / Video
10
Feb 15, 2009 07:58 AM
thrty8street
12
May 27, 2006 05:22 PM
jokerstud
13
Feb 20, 2003 10:59 AM
preludexl
Jan 30, 2003 09:31 AM
JDubya
Sep 14, 2002 06:25 AM
