distributor
Old May 22, 2006 | 06:59 PM
lsvtec_hatchback's Avatar
Default distributor?????
what will happen if you run the car w/othe litle spring that sits in the cap????????????????
Modified by lsvtec_hatchback at 8:11 PM 5/22/2006
Old May 22, 2006 | 07:32 PM
JimBlake's Avatar
Default Re: distributor????? (lsvtec_hatchback)
I guess it might do a lot of misfiring, or maybe not even run. Did you try that??
That spring completes the circuit from the coil's seconday tower over to the rotor. There's probably enough air gap that it won't arc over every time. Even if it did, the arcing would eventually damage the coil, cap, or rotor.
Old May 22, 2006 | 07:43 PM
Default Re: distributor????? (JimBlake)
ok thanx
LadyKiller1998
Aug 17, 2017 05:42 AM
IndySporty
Jul 27, 2010 01:19 AM
shaylude
Jun 17, 2010 08:19 AM
2camsaam
Oct 3, 2002 12:34 PM
GRM Scott
Mar 1, 2002 04:41 PM
