92-95 civic si wiring harness
Old May 22, 2006 | 06:11 PM
92 eg hatch's Avatar
Default 92-95 civic si wiring harness
Hey i have a 92' cx hatch and im dropping in a 92-95 b16. The wiring harness that is coming with the motor is set up for a right hand drive car. The guy im getting the motor from say that the b16 wiring harness with be cut at the firewall....so if you guys could give me some help on what is the easiest way to wire this thing up i would appreciate it. The car is a 92' cx hatchback with a d15 from the factory and I am swapping a 92'-95' b16 into it. Also if you guys know the best way to wire to vtec. Im kinda new at the whole wiring thing so i hope that you guys can help me out.
Thx
Old May 22, 2006 | 06:23 PM
Lord Helmet's Avatar
Default Re: 92-95 civic si wiring harness (92 eg hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 eg hatch &raquo;</TD></TR><TR><TD CLASS="quote">Hey i have a 92' cx hatch and im dropping in a 92-95 b16. The wiring harness that is coming with the motor is set up for a right hand drive car. The guy im getting the motor from say that the b16 wiring harness with be cut at the firewall....so if you guys could give me some help on what is the easiest way to wire this thing up i would appreciate it. The car is a 92' cx hatchback with a d15 from the factory and I am swapping a 92'-95' b16 into it. Also if you guys know the best way to wire to vtec. Im kinda new at the whole wiring thing so i hope that you guys can help me out.
Thx</TD></TR></TABLE>
easy way is get a any 92-95 civic ex/si engine harness and just add the knock sensor wire to it. it will have the VTEC wires in it but you still need to add the 3 wires for VTEC from the harness location to the ecu itself. BTW you can reuse your stock CX harness but you gotta change/add the VTEC wiring(in engine harness & cabin harness), convert the 1 wire 02 sensor wiring to 4 wire, etc... too much of a hassle if you ask me.
Old May 22, 2006 | 06:36 PM
Targa250R's Avatar
be professional
Default Re: 92-95 civic si wiring harness (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">easy way is get a any 92-95 civic ex/si engine harness and just add the knock sensor wire to it. it will have the VTEC wires in it but you still need to add the 3 wires for VTEC from the harness location to the ecu itself. BTW you can reuse your stock CX harness but you gotta change/add the VTEC wiring(in engine harness & cabin harness), convert the 1 wire 02 sensor wiring to 4 wire, etc... too much of a hassle if you ask me. </TD></TR></TABLE>
Apparently, all '92 Civics are pre-wired for VTEC from the factory regardless of trim level.
Old May 22, 2006 | 06:37 PM
95_eg_hatch_man's Avatar
also here is a web page that tells what wires go where http://www.jspecautosports.com...=17#2
Old May 22, 2006 | 06:56 PM
Default Re: 92-95 civic si wiring harness (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Apparently, all '92 Civics are pre-wired for VTEC from the factory regardless of trim level.</TD></TR></TABLE>
oh yeah I forgot about year
Old May 22, 2006 | 07:01 PM
sorry if you have already answered this question in your post but if 92' civics are already pre-wired for vtec what exact do i have to do to wire it up because i have no clue.
sicegcivic
Apr 26, 2004 12:42 PM
2.2L EH2
Jun 5, 2003 10:13 PM
92IntegraXSI
Nov 8, 2002 01:39 AM
highmilehatch
Mar 13, 2002 03:01 PM
