getting b18 for my 1991 civic hb , what would i need
Old May 22, 2006 | 05:08 PM
mikee91civic's Avatar
Default getting b18 for my 1991 civic hb , what would i need
i just need to know what i would need for the full conversion, i was told i wouldnt need much going with the b18.
Old May 22, 2006 | 05:18 PM
Mr. Giggles's Avatar
Default Re: getting b18 for my 1991 civic hb , what would i need (mikee91civic)
if you are talking about the GSR conversion then almsot everything you need comes with the conversion.. are you going through hmotorsonline.com?? I bought mine a little bit ago and i have a 91 crx HF and i picked up a whole brake set for like $75 and that includes the hubs that you need for an HF. You also need an ECU conversion harness.. you can get that from rywire.com
Old May 22, 2006 | 05:33 PM
d16vtecx's Avatar
SEARCH
Old May 22, 2006 | 05:58 PM
ludesrv's Avatar
Default Re: getting b18 for my 1991 civic hb , what would i need (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx &raquo;</TD></TR><TR><TD CLASS="quote">SEARCH</TD></TR></TABLE>
I wish that newbies couldn't post, only search, until the trial period is over.
Old May 22, 2006 | 06:09 PM
Loserkidwac's Avatar
Default Re: getting b18 for my 1991 civic hb , what would i need (ludesrv)
Well it is a fair amount of stuff but first we need to know what year and which b18, I just put a b18b(94-95 Ls integra) in my crx, the motor was OBD1 and I stayed OBD0, most if not all sensor are the same, you need the Dizzy that matches what your car is mostlikely you are still OBD0 if you are asking..uhm a tranny that matches your car cable auto/manual, a mid shaft and axles from a 90-93 Teg...a throttle cable from a 90-93 teg, custom/swap mounts I have AZ race tech they are exactly like Hasport but there are many out there, shift linkage again got the AZRT but there are other options like cutting a 90-93 teg linkage...rad hoses from a 90-93 teg or i made my low hose work from my crx...a ecu form a 90-91 teg if you stay obd0 or have yours chipped to run the b18....there is probabky more but I can think of it right now but thats a good start...HTH
Old May 23, 2006 | 03:46 PM
i see you must be the silly *** in this forum, i was just trying to figure out what would be cheaper the b16a or the b18c1
Old May 23, 2006 | 03:50 PM
stockbee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikee91civic &raquo;</TD></TR><TR><TD CLASS="quote">i see you must be the silly *** in this forum, i was just trying to figure out what would be cheaper the b16a or the b18c1</TD></TR></TABLE>
lol. perhaps you hit the nail on the head.
Old May 23, 2006 | 03:59 PM
mahatma's Avatar
Default Re: getting b18 for my 1991 civic hb , what would i need (stockbee)
Keep thinking there dipshit....it just might come to you.
Luward
Aug 6, 2013 03:37 PM
ef dino
Sep 30, 2008 07:32 PM
clarkhonda22
Feb 1, 2008 09:49 AM
ReV LiMiT
Jan 15, 2005 06:08 PM
93slmdcvcsi
Aug 6, 2004 08:32 AM
