h22 into eg, having some issues need help asap dailydriver
Old May 22, 2006 | 03:29 PM
4drsedaneg's Avatar
Default h22 into eg, having some issues need help asap dailydriver
i got my h22 into my eg, the engine tuns over no problem. im useing the stock harness and im not getting spark. ignition setup is msd blaster coil and msd 6a ignition box. when i turn over the motor it cranks and cranks and then makes a big bang after it gets a bunch of fuel in the cylinder. but it wont fire up. if any one has a wiring diagram or some advise for me it would be appriciated.
if it matters its a h22a1 with stock external coil.
Old May 22, 2006 | 03:56 PM
md23vtec's Avatar
Default Re: h22 into eg, having some issues need help asap dailydriver (4drsedaneg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drsedaneg &raquo;</TD></TR><TR><TD CLASS="quote">i got my h22 into my eg, the engine tuns over no problem. im useing the stock harness and im not getting spark. ignition setup is msd blaster coil and msd 6a ignition box. when i turn over the motor it cranks and cranks and then makes a big bang after it gets a bunch of fuel in the cylinder. but it wont fire up. if any one has a wiring diagram or some advise for me it would be appriciated.
Make sure the ignitor is working. Or try and bypass the MSD and check and see if your getting spark it's not unheard of for an MSD box to fail
Old May 22, 2006 | 04:09 PM
4drsedaneg's Avatar
Default Re: h22 into eg, having some issues need help asap dailydriver (md23vtec)
how do i check the ignitor??
Old May 22, 2006 | 07:42 PM
h22chilton's Avatar
* B A N N E D *
my dizzy took a **** after the first fire, rebuilt it cheap w/ crv internals. . . took a week to figure out.
rick22snail
Jan 8, 2013 09:34 AM
hatchback13sec
Oct 16, 2008 11:51 AM
BB6-213
Aug 17, 2005 05:05 PM
darockjc
Sep 30, 2004 10:35 AM
