Car idles really low but does not die?? Need help!!
My car idles at 2-400 RPMs but does not die. The car does not terribly shake like it is going to die, but it does shake a little. I tried adjusting the idle control valve (I'm not sure what its called exactly, the flathead screw on the intake manifold) but it doesn't do anything. Any ideas?
check for VAC leaks, and adjust the screw on the throttle body not the intake manifold. you could have a bad IAC (Idle Air Control Valve)
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">check for VAC leaks, and adjust the screw on the throttle body not the intake manifold. you could have a bad IAC (Idle Air Control Valve)
platinum.</TD></TR></TABLE>
Why do you always say "platinum" at the end of your posts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">Why do you always say "platinum" at the end of your posts?</TD></TR></TABLE>
^^ wth does that have to do with this guys question?
My fault, I meant the throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet »</TD></TR><TR><TD CLASS="quote">any CELs showing? </TD></TR></TABLE>
No, there is no CEL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yongster22 »</TD></TR><TR><TD CLASS="quote">has anyone ever messed with your timing, or it might be that your valves might need to be adjusted. </TD></TR></TABLE>
I had 60k maintenance done at Honda, but I thought they don't touch the timing belt until 90k maintenance?
candyblueta
Engine Management and Tuning
Jan 8, 2009 08:59 PM
