ac relay ??? where???
Old May 22, 2006 | 02:01 PM
mako1's Avatar
Default ac relay ??? where???
the ac is out
charge is good, fan comes on,idle jumps
all fuses are good , all fuse links good
all relays i could find good
still no power coming up clutch wire to compressor
where the *&#$@#!$ is the ac relay
bypassed the clutch wire,to the + compressor jumps to life pumping out flows of cold
any body, bueller?? bueller??
Al
Old May 22, 2006 | 02:55 PM
Ruskimafia's Avatar
i dont know wat year car u got but wen i went to Papa auto parts in my area they said accord 95-01 had the sameclutch relay here is a pic off my 2000 accord v6 jsut had ac replaced
Old May 22, 2006 | 03:07 PM
sj993's Avatar
Default Re: (Ruskimafia)
I suppose it depends on the year. The relay in the fuse box is for the radiator fan on 94-97 accords. I think the A/C relay is in the driver side front area. Next to the fan.
Old May 22, 2006 | 03:18 PM
mako1's Avatar
Default Re: ac relay ??? where??? (mako1)
Oh maybe what year i've got will help
2001 accord ex
i'll chec that relay again
you never know
i''l LYK
Al
Old May 22, 2006 | 03:30 PM
sj993's Avatar
I took a few pics
the layout should be similar..the pics are from and for a 95 accord.
Old May 22, 2006 | 03:53 PM
Ruskimafia's Avatar
Default Re: ac relay ??? where??? (sj993)
the relay for the ac clutch is located in a diff location in a 01. i just got my car out off the shop today b/c ac didnt work i got a new compresser and ac relay
Old May 22, 2006 | 04:26 PM
mako1's Avatar
Default Re: ac relay ??? where??? (Ruskimafia)
found the relay..
there is no power to the relay
on the side that matters
and NO fuse is bad
bad wire connection behind relay or fuse??
Al
Old May 22, 2006 | 04:42 PM
sj993's Avatar
Probably bad wire
TheCoolNamesAre
Sep 8, 2018 09:55 AM
Xjbw1983
Aug 30, 2016 01:49 PM
David_S
Apr 26, 2014 11:28 PM
ThisBeDuy
Sep 30, 2011 09:16 AM
delta901
Jul 17, 2005 03:15 PM
