95 Accord with h22a Clutch problem
Hey guys, I got this 95 accord with an h22a swap and lsd tranny and I have been having a bunch of stupid problems. I got the car started and drove it around town and then something happened and I couldn't shift into any gears. It didn't make any loud sound or anything, but the clutch just stopped engaging into any gear. I got the car towed back to my house, and now the problem fixed itself somehow. Does anyone know what electrical part could stop my clutch from engaging? I think it is electrical because the wiring on the car is not that great, I plan on getting it redone. I just don't understand what could be causing this problem. PLEASE HELP..
thanks
thanks
sounds more like a clutch master leaking, very common problem on those cars. there is nothing electrical in the clutch system that effects shifting.
I will check that out, I just got a new clutch put in so maybe they didn't put enough fluid or the clutch master is bad. Anybody else got any suggestions, how to diagnose this problem.
thanks lot
this forum kicks=as*
Modified by bpot555 at 7:43 PM 5/26/2006
thanks lot
Try bleeding the system, whoever did it may not have done a great job which is why it's intermittently happening. But as said previously it could be your master or slave cylinder. Mine went out after replacing my clutch, around 150 -160,000 miles on it.
