What Clutch do I use?
all b-series clutches are the same u can put a hydro clutch in a cable tranny the only difference is the throw out bear. hydro clutch with cable throw bearing will work just fine, you can get a 90-99 bseries cluth just buy a new cable throw bearing. its the same with a D-series as well.
no like if you have a dseries hydro clutch and you have a dseries cable tranny than it will work the only thing that b and d series share is the bolts
bseries spline are way bigger than a dseries
for your bseries you need either a
B series:
cable throw out bearing
and either or a hydro or a cable clutch
the differents between a cable tranny and a hydro tranny is the throw out bearing
B series:
EG6-SIRII
Feb 3, 2006 06:59 AM
SnowSurfer
10
Jun 15, 2005 01:57 PM
