92-95 Radiator
Old May 22, 2006 | 10:42 AM
Fezzie's Avatar
Default 92-95 Radiator
Ight what I want to do is put a 92-95 radiator on my 90 sedan but I want to know is there anything i have to change or anything special i have to do can someone help me?? I think its called the half radiator
Modified by Fezzie at 11:55 AM 5/22/2006
Old May 22, 2006 | 10:45 AM
Fezzie's Avatar
Default Re: 92-95 Radiator (Fezzie)
Old May 22, 2006 | 10:55 AM
Fezzie's Avatar
Old May 22, 2006 | 11:59 AM
IpatXcoreI's Avatar
it wont just fit right in there.. u will have to do some cutting and some angling or if u want it nice and up right you will have to get an aftermarket crossmember that will allow you to use a half rad.. .
good luck.
Old May 22, 2006 | 12:01 PM
Autoworks's Avatar
Default Re: 92-95 Radiator (IpatXcoreI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IpatXcoreI &raquo;</TD></TR><TR><TD CLASS="quote">it wont just fit right in there.. u will have to do some cutting and some angling or if u want it nice and up right you will have to get an aftermarket crossmember that will allow you to use a half rad.. .
good luck. </TD></TR></TABLE>
false
It is possible to get the EG radiator in perfectly verticle with a stock crossmember, it just takes a lot of work ( bangin)
Old May 22, 2006 | 12:06 PM
dohc_profile's Avatar
dont mean to jack your thread but...since we're on the topic...all 88-91 civic radiators same size? and bolt right up? thanks.
Old May 22, 2006 | 12:07 PM
Autoworks's Avatar
Default Re: (dseries_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dseries_ef &raquo;</TD></TR><TR><TD CLASS="quote">dont mean to jack your thread but...since we're on the topic...all 88-91 civic radiators same size? and bolt right up? thanks. </TD></TR></TABLE>
height yes, you can get some that are shorter in side to side length (for some reason)
Old May 22, 2006 | 12:16 PM
88crxvtec's Avatar
Default Re: (Autoworks)
some of the std editions had 3/4 radiators for some reason.
Old May 22, 2006 | 12:27 PM
ok so even if its shorter it wont matter then? thanks for hte help as long as its bolts in without any cutting etc.
Old May 22, 2006 | 02:41 PM
firebane's Avatar
EG rad in my 89 hb. Had to cut and bend part of the rad support out but she sits flat and flush and hood closes fine
Old May 22, 2006 | 03:34 PM
d357r0y's Avatar
Default Re: (firebane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firebane &raquo;</TD></TR><TR><TD CLASS="quote">EG rad in my 89 hb. Had to cut and bend part of the rad support out but she sits flat and flush and hood closes fine </TD></TR></TABLE>
Post some pictures
Old May 22, 2006 | 09:55 PM
Fezzie's Avatar
Default Re: (d357r0y)
Old May 23, 2006 | 10:30 PM
firebane's Avatar
tell ya what when it stops raining.. I'll pull my bumper off and take them for ya guys As I still sorta have to finish up it and paint the cut metal before she starts to rust :D
Old May 24, 2006 | 10:22 AM
Fezzie's Avatar
civics4lyfe
Jan 22, 2009 09:28 PM
nfereorhatch
Jun 1, 2008 03:11 PM
sleepin91teg
Nov 16, 2004 10:53 AM
RussHondaCRXVtec
Nov 18, 2003 11:26 PM
b16EF
Oct 30, 2002 10:28 PM
