HELP! brakes are really soft
Ok I have a 92 civic si, just got new rotors and pads and two new rear calipers. when the engine is running the pedal goes almost to the floor before any kind of braking occurs and its a really soft pedal. With the engine off you can build up pressure but it doesn't seem enough, because I compared it to my 93 accord with the engine off. I just got a new master cylinder because I thought that was the problem but it wasn't so Im out of ideas. I don't see any leaks anywhere either. Please help
Mine started when I took the master cylinder out of the booster to make room to get to the IAT. When i put it back on it just like how i took it off it started the soft brakes, I don't think I moved or broke anything because it only goes on one way.
i had the same thing happen to my eg after i installed new break pads. kept bleeding it but no matter what it was still soft to the metal. try driving around for a few days like that, thats what i did and it went back to normal after a few days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyMach »</TD></TR><TR><TD CLASS="quote">Sounds like theres still air in them. I bet you didn't bleed them all the way. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">the mc has just been replaced by a trusted mechanic and the pedal still feels the same for me. No air in line.
yeah my sister's car has the same thing. i bled the brakes twice, still soft. swapped my master cyl & booster in there, bled again, still soft. i can push the pedal all the way to the floor easily. the brakes don't really start to grab till it's about 1" from the floor. her master cyl is in my car now and my pedal is rock solid, wtf is going on?
no leaks that i can see anywhere either. running the cobalt fluid in both cars, mine is rock solid, her's is really spongey. bled multiple times, there's no way air is in there, wtf??
</TD></TR></TABLE>yeah my sister's car has the same thing. i bled the brakes twice, still soft. swapped my master cyl & booster in there, bled again, still soft. i can push the pedal all the way to the floor easily. the brakes don't really start to grab till it's about 1" from the floor. her master cyl is in my car now and my pedal is rock solid, wtf is going on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowek04 »</TD></TR><TR><TD CLASS="quote">get new mc, check ur lines and bleed again.</TD></TR></TABLE>
If you wernt so ******* retarded then you would know, that people have done this multiple times already. READ what people are typing
91integra91
13
Aug 20, 2011 09:00 AM
