QUESTION LS/vtec?
Old May 22, 2006 | 08:00 AM
Sloshy's Avatar
Default QUESTION LS/vtec?
ok, I dont know which timing belt I'm suppose to use. I have a GSR head on a b18 block. Can any one help me on this one? thanks in advance.
Old May 22, 2006 | 08:37 AM
Brodie Bruce's Avatar
Default Re: QUESTION LS/vtec? (hatch-E-vanish)
your block is a b18__ ? What letter? It will also depend on what water pump you are using.
Old May 22, 2006 | 08:51 AM
Sloshy's Avatar
Default Re: QUESTION LS/vtec? (Brodie Bruce)
b18a block for sure
not sure which water pump
if it was gsr, ls, or b16 which would it be?
Old May 22, 2006 | 10:19 AM
92_VX_EG's Avatar
I think it goes by the water pump. My buddies has a B18A1 with a GSR water pump, B16 head and he used a GSR timing belt. You should look in the search.
Old May 23, 2006 | 06:48 AM
Sloshy's Avatar
i dont htink it goes with water pump i have b16 block with a GSR pump, so i bought a gsr timing belt and it didnt fit so i wasted my money on that because the dealer didnt want to take it back, at the end it fitted a b16 t-belt
Old May 23, 2006 | 06:52 AM
Default Re: (hatch-E-vanish)
so do you have a b16 or a b18 block????
Old May 23, 2006 | 07:00 AM
Sloshy's Avatar
Default Re: (Brodie Bruce)
well actually for this one is a B18a block with GSR head... which timing belt?
ps. gsr water pump
Old May 23, 2006 | 07:48 AM
gold_ef's Avatar
gsr timing belt, its the only one that will work right without jumping a tooth or 2 and destroying ****...as a rule go by the head your using, if your still trying to figure out what head studs/bolts to use you need to use gsr studs/bolts
edit: i would have answered this yesterday when i saw it but my 5 posts for the day were already gone
b16bhatch
Sep 20, 2007 06:44 AM
B6tizzleHatch
14
Aug 14, 2006 08:49 PM
del slw
Feb 1, 2006 04:02 AM
hitvtecgetloud09
14
Jul 12, 2005 06:43 AM
ScottEK
Jun 26, 2005 01:58 PM
