flywheel i think
Old May 22, 2006 | 12:17 AM
JJ's civic's Avatar
Default flywheel i think
when i'm on my gass and i have to shift but don't and go to slow down my motor slows down(rpms0 is slow how can i make it come back to idle faster. light flywheel??
Old May 22, 2006 | 12:19 AM
tek_civic's Avatar
im not sure what your asking.
a lighter flywheel will make the engine more responsive when the clutch is in. so rpms drop faster between shifts, and it revs up faster when the clutch is in.
i think that might help.
Old May 22, 2006 | 08:33 AM
JJ's civic's Avatar
Default Re: (tek_civic)
yea i am lookin gfor way to make the rpm drops faster. alot faster
Old May 22, 2006 | 08:59 AM
EP3_05's Avatar
Default Re: flywheel i think (joeny12985)
A lightweight flywheel is what you are looking for.
Old May 22, 2006 | 09:03 AM
ludesrv's Avatar
I don't see why you would wanna do that on a stock engine...
Judging by your signature you are cheap with your car (all show no go cause it costs too much) then get your stock flywheel machined. You can lose 4-5 lbs.
Old May 22, 2006 | 11:58 AM
JJ's civic's Avatar
Default Re: (ludesrv)
it's nto that i'm cheap i'm just poor. but i already had my stock flywheel machine when i got a new clutch it just the motor seem to drop too damn slow. and yes it is a stock motor as of now but i dunno is there any other way to do the samething?
Old May 22, 2006 | 12:38 PM
si90rex's Avatar
Default Re: (joeny12985)
I other words you want the motor to rev faster. let the dam think breath get u a header and exhaust and a cold air that right there should be what your looking for. a lighten flywheel is to much it'll spike when you hit the gas but that's not a good think for something if the air fuel mix and exhaust have no were to go just a high flow cat and 2" exhaust should do the trick
Old May 23, 2006 | 07:21 PM
JJ's civic's Avatar
Default Re: (si90rex)
so if i get a CAI and exhaust that should do the trick? I'm not really looking fo rpower gain i'm really jsut lookign for sumthing to alone the revs to slow. I drive for a living and if i step on it to get out into traffic and then have to stop at another light i dont feel like up shifting to bring the motor down. i dont see the sense?(up high in the rpms)
srm238
Nov 28, 2009 10:54 AM
rick_rabies
Jul 11, 2009 10:40 AM
turbo_b16_ex
Sep 12, 2006 03:11 PM
LSeeper
Oct 31, 2003 11:55 AM
ActiveAero
Jan 4, 2003 08:50 AM
