My car wont start!!!!
Old May 21, 2006 | 09:06 PM
UrbanEh's Avatar
Default My car wont start!!!!
Heres the deal, I just replaced the starter in my hatch (which has a H22a motor). Now, when I turn the key nothing happens. Before I replaced the starter, the old one clicked but the motor didnt turn over. My battery is charged, I have gone over all my connections a few times. I have no idea what is going on. I turn the key and the dash lights come on, everything works but nothing from the starter!!!!!! Please help me electrical gurus!!
Old May 21, 2006 | 09:16 PM
UrbanEh's Avatar
Default Re: My car wont start!!!! (UrbanEh)
bump
Old May 21, 2006 | 09:59 PM
92_VX_EG's Avatar
Check your grounds and fuses.
Old May 21, 2006 | 10:01 PM
midnitesol's Avatar
Default Re: My car wont start!!!! (92_VX_EG)
Had same problem make sure the clutch sensor wire is connected to the starter!
Old May 21, 2006 | 11:04 PM
UrbanEh's Avatar
Default Re: My car wont start!!!! (midnitesol)
Thanks for the info, I will check tomorrow; again. Any other tips? Anyone?
Old May 21, 2006 | 11:14 PM
professor poon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UrbanEh &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info, I will check tomorrow; again. Any other tips? Anyone?</TD></TR></TABLE>
Did you push the clutch down? lol
Old May 21, 2006 | 11:18 PM
UrbanEh's Avatar
Default Re: My car wont start!!!! (professor poon)
Thanks for the bump
Old May 21, 2006 | 11:24 PM
thahuhstunna's Avatar
bump for another H22 EG... hope you get it back on the road soon
Old May 22, 2006 | 05:22 AM
UrbanEh's Avatar
Default Re: My car wont start!!!! (thahuhstunna)
Thanks for the bump I love my car, whenever it works!
Old May 22, 2006 | 07:07 AM
93DXcoupe's Avatar
did you try putting the key in the on position make sure the car is in neutral of course and jumping the starter cause if that works then you know the problem is in the wiring somewhere between the key and the starter
Old May 22, 2006 | 07:38 AM
UrbanEh's Avatar
Default Re: My car wont start!!!! (93DXcoupe)
I did that, the starter sparked a little but didnt turn over. Also when I did that the gauges went crazy inside the car. I think it has to be in the wiring.
Old May 22, 2006 | 07:43 AM
Turbo_y8's Avatar
could be the ignition switch, or soleniod
Old May 22, 2006 | 09:23 AM
jdeemseerx's Avatar
check to see if you have both wires hooked up to the starter batt + and the one from the harness..thats my guess
Old May 22, 2006 | 09:50 AM
UrbanEh's Avatar
Default Re: My car wont start!!!! (Turbo_y8)
If the ignition switch is bad will all of the dash lights and headlights come on? And if it is that how do I change it out? Thanks for the help
Old May 22, 2006 | 10:31 AM
Turbo_y8's Avatar
Dash lights will come on once the key is in the run position, the start postion maybe bad, and the head lights work if the keys arent even in the ignition
DriveSlowHomie
Jan 26, 2010 10:31 PM
Offspring EK
22
Dec 9, 2009 04:55 PM
Timmyflys
28
Jun 25, 2007 03:11 PM
95greenteg
Nov 7, 2005 01:29 PM
ILOVEGIRLS
Sep 5, 2003 12:03 AM
