self rev
Old May 21, 2006 | 08:22 PM
KillerElfboy's Avatar
Default self rev
hey, i cleaned my iacv today and it ran great afterwards, i just took it out around the block tho and when i put it in park it started to rev itself like it used to, could i not have cleaned it enough? i had to use a screw driver to chisel the buildup out of the two pipes on each side so i thought it would have fixed it... didnt tho, my tach still sits at 1.6 when it isnt reving itself. Any ideas?
also, if i need a new iacv, can i use the one out of my 91 DX?
Old May 21, 2006 | 09:55 PM
OuttaGas's Avatar
vacumm leak
Old May 21, 2006 | 10:33 PM
YeuEmMaiMai's Avatar
Default Re: (OuttaGas)
since you cleaned verything, take some soapy water and spray all of your vaccum lines to see if you can find a leak......
Old May 22, 2006 | 04:52 PM
Default Re: (YeuEmMaiMai)
ok i just took it out, put it in park and this time it didnt do it. i dont know if that helps or not, but aight its getting dark i'll do this in the morning. if not a vaccumm leak what else could it be? and what hoses do i check for this/
Old May 22, 2006 | 09:55 PM
92accordundrconst's Avatar
Default Re: (KillerElfboy)
i had a simliar problem on my 92 accord. only it would drop to 200rpms and then go up to 800rpms and just go up and down when it was in neutral. cleaned the iavc and it stopped doing that only now it would stay at 1800 rmps at all times when in neutral. so what i did was if you notice in your engine compartment there is a thing which if you apply pressure on(pull to the left), the engine will rev (sorry don't know what it's called), that has a cable which it pulls on when you rev it, in the middle of that cable there are some bolts/nuts with some other thing, loosen those bolts a bit until it lowers itself to 1000rpms which is where i think your car is supposed to be at. first loosen the one on the right and then tighten the one on the left so that it stays firm, that fixed my problem i don't know if your car is the same though, but it's worth a try.
i wonder that makes any sense ....probably not
Old May 22, 2006 | 11:07 PM
Default Re: (92accordundrconst)
mine still fluctuates, tho i will look at that throttle cable good idea,
what is the correct rpm after a car is warmed up? 900?
Old May 22, 2006 | 11:49 PM
yeah 900 rpms. on my 92 it's 900 rpms, and i believe its 900 rpms for all 4th gen accords. read it somewhere on those haynes manuals.
Old May 22, 2006 | 11:51 PM
just saw your sig, so yeah 900 rpms after warmed. i thought you had a 5th gen.
thayerboy182
Mar 11, 2010 06:44 PM
cheesecheda
Oct 22, 2008 12:17 PM
srburk
May 21, 2008 10:28 AM
ReGMiLLa31
Honda S2000
Oct 28, 2006 07:28 PM
DC5ftmfw
Sep 28, 2006 04:42 AM
