how do i wire vtec in 93 civic dx
Old May 21, 2006 | 08:22 PM
B_SERIES_BITCHEZ!'s Avatar
Default how do i wire vtec in 93 civic dx
i need a ex or si harness im pretty sure but what about the ecu? do i have to add wires?
Old May 21, 2006 | 08:38 PM
JD95hatch's Avatar
Default Re: how do i wire vtec in 93 civic dx (B_SERIES_BITCHEZ!)
Old May 21, 2006 | 08:40 PM
inspector01's Avatar
You do not need the harness, but you do need the Vtec sensor plugs from a Vtec Harness. You could use a full EX or Si harness if you wanted to but you would have to splice into the Vtec wires before you hook it up to the chassis harness. You need to hook up the Vtec sensor directly wired into the ECU but i don't remember which spot you need to clip it in to. Search it cuz there are hundreds of write ups out there on how to do it.
Basically you just take the Vtec Sensor Harness plugs and splice a wire from that directly into the ECU, Pretty simple.
Old May 21, 2006 | 08:48 PM
THANKS FOR YALLS HELP GUYS
Old May 21, 2006 | 08:49 PM
JD95hatch's Avatar
Default Re: (inspector01)
ya..all u need is 2 plugs...and some wire...run the wires throught the firewal and spliced into teh ECU...simple
egkiller94
Dec 20, 2010 01:34 AM
projecthonda
Feb 23, 2007 06:48 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
streetracerof06
Nov 9, 2005 02:30 PM
hatchedzex
Apr 12, 2004 02:41 PM
