Is it possible??????
Old May 21, 2006 | 07:28 PM
Ba-Bo's Crx's Avatar
Default Is it possible??????
Hey im putting a b18 from a 93 acura integra in my 1990 honda crx and i was wandering if it was possible to put that in there and still keep my stock trany. if not is there a conversion that i could buy to keep it or do i have to have the trany from the b18? if you know PLZZZZZZZzz comment
Old May 21, 2006 | 07:31 PM
little white crx's Avatar
Default Re: Is it possible?????? (Ba-Bo's Crx)
http://www.hasport.com
Old May 21, 2006 | 07:32 PM
Stunna MIKE's Avatar
You can't use a d-series tranny on a b-series motor.
Old May 21, 2006 | 07:41 PM
philkehn's Avatar
Yes thats right a d series is basically sohc, while a b series is dohc, so you would different tranny depending on if it was d or b series, also you shouldnt have to much trouble for the crx SiR's engine bay is the same thing as a 90-93 integra engine bay so you should be able to get some mounts for a b16 swap that would work, again try http://www.hasport.com im not to sure on the wiring you may need to change a couple things depending on the ecu, and if you crx is a dx model you will have to also change your dpfi to a mpfi
chase4462000
Jan 29, 2008 07:54 PM
WookinPaNub
Classic Hondas
Nov 6, 2007 01:55 PM
Toddius_maximus
May 30, 2007 03:57 PM
420Raider
Aug 1, 2005 03:14 PM
RC_SKUBY
Dec 20, 2002 08:34 AM
