88 CRX DX LCA question
Old May 21, 2006 | 05:01 PM
primetimedx's Avatar
Default 88 CRX DX LCA question
As it states, I have an 88 DX, the model with the pain in the *** suspension that makes it hard to find struts for the rear for a decent price. I have 2 rear tokico's from an 89-91 but they obviously dont fit. I was curious, could I swap in stock 89-91 LCA's without a problem or do I need the whole rear suspension? OR what LCA's could I use that would be easy to come across without breaking my wallet. Please any help would be great. Thanks!
Old May 21, 2006 | 05:08 PM
Crx Jimmy's Avatar
Default Re: 88 CRX DX LCA question (primetimedx)
yes any 89-91 control arms will work, you might as well get si ones, this way if you decide to upgrade to a rear swaybar the mounting holes on the arm are already there
Old May 21, 2006 | 05:34 PM
88 rex's Avatar
I don't think it's a pain in the but to find anything for it, but yes, you can swap over the LCA's.
Old May 21, 2006 | 06:01 PM
thanks guys... I appreciate the help!!
but can I use EF Civic Si LCA's or do they have to be CRX???
Old May 21, 2006 | 06:07 PM
88 rex's Avatar
Civic's should work. Heck I have ITR LCA's.
Old May 24, 2006 | 07:37 PM
Default Re: 88 CRX DX LCA question (88 rex)
If I keep these 88 DX LCA's are there any other type of struts I can use besides model specific... I have seen some posts that say that integra struts will fit into the 88 LCA's, but a definate answer would be great. What are some suspension options that I have? thanks in advance for the help.
Old May 24, 2006 | 08:06 PM
EL Vap133's Avatar
Default Re: 88 CRX DX LCA question (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">yes any 89-91 control arms will work, you might as well get si ones, this way if you decide to upgrade to a rear swaybar the mounting holes on the arm are already there</TD></TR></TABLE>
Correct, it is a direct swap!
Old May 24, 2006 | 08:07 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primetimedx &raquo;</TD></TR><TR><TD CLASS="quote">If I keep these 88 DX LCA's are there any other type of struts I can use besides model specific... I have seen some posts that say that integra struts will fit into the 88 LCA's, but a definate answer would be great. What are some suspension options that I have? thanks in advance for the help.</TD></TR></TABLE>
There are quite a few companies that make the 88 style rear struts, just look around. They do cost a bit more though.
Old May 24, 2006 | 08:08 PM
Default Re: 88 CRX DX LCA question (EL Vap133)
yea I have noticed the high cost... do you know if integra or any other model honda struts will fit into the 88 LCA's??
Old May 24, 2006 | 08:11 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primetimedx &raquo;</TD></TR><TR><TD CLASS="quote">yea I have noticed the high cost... do you know if integra or any other model honda struts will fit into the 88 LCA's??</TD></TR></TABLE>
ITR rear shocks will fit, if you buy them through say Bilsteein they use the same part number for the ITR and 88 CRX rear shocks.
Old May 24, 2006 | 08:42 PM
jccrxtuner916's Avatar
i also have a 88 dx.. and i bought a 93 ls which had been hit, and im going to part out, now can i use the rear lower arms for my 88 dx? would they fit... casue i dont want to take the integra part and not be able to move it.... anybody done that b4??
Old May 24, 2006 | 09:37 PM
EL Vap133's Avatar
Default Re: (jccrxtuner916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jccrxtuner916 &raquo;</TD></TR><TR><TD CLASS="quote">i also have a 88 dx.. and i bought a 93 ls which had been hit, and im going to part out, now can i use the rear lower arms for my 88 dx? would they fit... casue i dont want to take the integra part and not be able to move it.... anybody done that b4??</TD></TR></TABLE>
I wouldn't recommend it, the Integra arms are longer.
efjones9
13
Mar 1, 2009 08:58 PM
happy!
29
Jun 7, 2005 06:23 PM
mike84 CRX-GTL
Sep 27, 2004 05:46 PM
ecsahs3
Jul 7, 2004 10:59 PM
speeddave
Mar 22, 2003 05:35 PM
