Accord alternators; interchangeable newer OEMs??? 1990 with what?
Old May 21, 2006 | 04:22 PM
Mangotreemechanic's Avatar
Default Accord alternators; interchangeable newer OEMs??? 1990 with what?
I want to replace the alternator in my 1990 Accord EX. Is it possible to use the alternator from a newer model year Accord (or even Civic, for that matter)? The engine is the F22A4 4 cyl SOHC. I will try to get the Honda part number if that would help (probably only if getting it from a Honda dealer). Thanks.
Old May 21, 2006 | 07:43 PM
AFAccord's Avatar
Default Re: Accord alternators; interchangeable newer OEMs??? 1990 with what? (Mangotreemechanic)
An alternator from a 4th gen has the same chassis as from the 6th gens, but you'll have to swap the voltage regulator. (OEM power plug and circuit board beneath it)
I did this when I swapped a built 180amp alt from my 90 accord lx to my 99 accord lx.
Old May 22, 2006 | 05:56 PM
Default Re: Accord alternators; interchangeable newer OEMs??? 1990 with what? (AFAccord)
Thanks for the reply and info. Does the alternator chassis carry forward into the 7th gen 4 cyl engines?
Old May 23, 2006 | 11:25 PM
I was looking at parts lists. The alternators have different part numbers. Some of this is because the alt was provided for the same year by more than one manufacturing supplier. Then each Accord generation has an alternator with different part numbers perhaps due to amps differences, but not great changes.
Is it safe to say that all alternators are interchangeable within the 1990 thru 1997 Accord years?
Is the built-in regulator/rectifier attached inside the back of the alternator?
Old May 23, 2006 | 11:58 PM
AFAccord's Avatar
I'm sure each alternator would have a different part number since the plugs are different. From what i remember, the plug is connected to a circuit board type device that I believe is the voltage regulator. I removed both to swap my alternators.
I don't have any experience about 5th or 7th gen 4cyl Accords, though I would guess the 5th gen is the same as 4th and 6th.
Biglbg
Jun 20, 2019 05:31 PM
bobinator5000
Jul 27, 2010 05:38 PM
flarinpnoi
Nov 20, 2006 12:54 PM
sackdz
Jun 18, 2004 03:59 PM
aanderson77
Jan 4, 2004 06:43 PM
