turbo b18b head gasket problems....
i recently purchase a stage 4 motor from spark racing a b18a with 84mm arias pistons for turbo , since i got it i been blowing head gaskets constantly , is not the first engine I put together I had a similar problem with my eclipse but it was due to a regular organic type gaskt I got a metal gasket for it and the problem was solve , now for my b18a vtec i been blowing stock head gaskets , well I can not say blow it does not seals good because the car burns white smoke and it over heats, what head gasket u guys will recomend me and were can I buy it? I was thinking Copper gaket??
thanks
thanks
http://www.cometic.com or http://www.goldeneaglemfg.com
Make sure the head and block are smooth and flat.You need one for a 84mm bore as the stock bore is 81mm.A stock bore gasket will not work.
