ok guys i have a question its kinda an alarm for my 89 crx si i bought from a hack
Old May 21, 2006 | 02:31 PM
viciousvisionslarry's Avatar
Default ok guys i have a question its kinda an alarm for my 89 crx si i bought from a hack
ok i have reason to believe my car had an alarm because theres a horn under the hood i also have reason to believe i bought this car from a hack because there where philips head screws holding the fenders on and wire nuts wiring the headunit in.ok heres my problem im putting everything back together well i put the passenger corner light bulbs in and corner lense in and when i hook up the battery the bulb stays on all the time its the only one that im having a problem with im assuming its from the removal of an alarm. what should i be looking 4?
its a 1989 crx si
Old May 21, 2006 | 03:48 PM
Kavehman's Avatar
try taking the bulb out and putting it back in again
Old May 21, 2006 | 03:52 PM
Default Re: (Kavehman)
i did that it still lights up
Old May 21, 2006 | 07:58 PM
STK B16's Avatar
Default Re: (viciousvisionslarry)
try locating the ALarm Main Unit.. which usually is under the driver dash.. Unplug the whole unit.. and see if the light shuts off.. if it doesnt. then somethin else is wrong and that the alarm is not causing that light to Light up... this way you will save time uninstalling the whole thing finding out it wasn't the alarm..
Old May 22, 2006 | 03:22 AM
Default Re: (STK B16)
the alarm unit was removed and everything was rewired i think thats my problem it was rewired wrong
Amypinkx
Jun 24, 2009 05:10 PM
WongFeihung
Oct 8, 2003 12:14 PM
GSlowR
Aug 19, 2001 10:58 PM
