car bogging when vtec kicks in.
i think im having fuel problem,checked everything else.car starts to break up at 3500 rpms.i dont think its the fuel filter.any ideas what else it could be.at a quater throddle it will rev up in rpm but half or more motor breaks up??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MitsuGTRacing »</TD></TR><TR><TD CLASS="quote">Could be the PCV valve man... Check it out.</TD></TR></TABLE>
that has nothing to do with it. are you throwing any codes. check the tps and see if its witghinn range. seems like its at 1.5 at closed throttle for you and you are not getting full throttle response. check it with a volt meter and at closed throttle it should be .5V and at wide open throttle it should be at 4.5V
si del sol 94
18
Sep 16, 2009 07:39 PM
dmotoguy
Oct 16, 2003 02:51 AM
