Is there a way to distinguish a Skunk 2 Ecu from the other ECUs? Is there a way to tell?
Old Apr 12, 2002 | 12:08 PM
IeatMinuteRice's Avatar
Default Is there a way to distinguish a Skunk 2 Ecu from the other ECUs? Is there a way to tell?
Old Apr 12, 2002 | 03:10 PM
fixhondas's Avatar
Default Re: Is there a way to distinguish a Skunk 2 Ecu from the other ECUs? Is there a way to tell? (IeatMi
ask skunk2- they should know
Old Apr 12, 2002 | 03:47 PM
AzG35's Avatar
Well, not really. A Skunk 2 ECU is just a P28 chipped to their spec. You can open up the ECU and see if they marked the "chip" on the board or not. If you don't know where to look, try this http://www.hondata.com/techecuanatomy.html
Old Apr 12, 2002 | 04:19 PM
Shft@9GSR's Avatar
I have a skunk2 ecu and the only way I can tell is that it has a big sticker on the case of the computer that reads "SKUNK2" with a serial number on it. i never opened the ecu to see if a chip was marked.
Old Apr 15, 2002 | 01:00 PM
Rocket's Avatar
The specs are 5800 rpm VTEC cross over with a 9500 rpm redline.
But the only way to tell for sure is to read the chip and compare it to a real Skunk 2 chip.
Old Apr 16, 2002 | 04:17 PM
thanks for the replys
ttt
hood ride eg
Southern California
Aug 30, 2010 01:39 AM
pxsx
Sep 26, 2007 07:29 PM
1stGENGSR
17
Apr 13, 2004 10:23 AM
Dragger817
Sep 4, 2002 09:29 AM
