D15B into a 94 EX...direct plug in?
I have a 94 EX with a dead z6 and I am looking to order a D15B from Hmotorsonline.com and I am wondering if the Z6 engine harness plugs in perfect as it does on a Z6. Since its a jdm motor im guessing something is diffrent but im not sure. thanks
It will plug in. However, if you are running te P08 ECU, then you'll need to convert to 1-wire O2 sensor. You won't need to plug in the pressure switch either since JDM engines don't have it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">^^
Or keep your p28 and Z6 o2 sensor and chip the p28, which is better than the p08.</TD></TR></TABLE>
But then he will need to add the pressure switch. Unless when he chips the P28, he can ask to bypass it.
if its a cx or dx d15 then it is a straight plug in and if its the vx d15 then u need to run the 5 wire o2 and ecu and wire it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
But then he will need to add the pressure switch. Unless when he chips the P28, he can ask to bypass it.</TD></TR></TABLE>
Yea, since he will HAVE to get it chipped to have it run correctly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rus1an »</TD></TR><TR><TD CLASS="quote">How about if I run the p28 with it and a 4 wire O2. Will I have to add a pressure sensor since I am using the p28?</TD></TR></TABLE>
Yes, since the ECU will look for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rus1an »</TD></TR><TR><TD CLASS="quote">Sorry for all the questions... so i just swap vtec solinoids?</TD></TR></TABLE>
No, you need to buy a VTEC oil pressure switch.
NO YOU DONT, just use a usdm vtec solenoid. they have the pressure switch in them. i dont know why he said buy one, use the z6 vtec solenoid, it has the pressure switch in it. then just use the P28.
ef9allday
Mar 22, 2013 09:46 PM
