alternator belt keeps snapping.
Old May 21, 2006 | 12:05 PM
Import_Dumbass's Avatar
Default alternator belt keeps snapping.
ive replaced it the passed two sundays now. can anyione give me any hint on why my alternator belt keeps snapping, this is probably the 7th or 8th time its happened in a few months. any feedback really will help, thanks.
oh yeah and it squeels alot, normally when it snapps i can tell it will squeel really hard for like 10 minutes or so and then just snap. and it squeels alot off and on.
Old May 21, 2006 | 12:15 PM
Chiovnidca's Avatar
Default Re: alternator belt keeps snapping. (Import_Dumbass)
What's locking up? Alt? A/C? Idler?
Old May 21, 2006 | 12:16 PM
Default Re: alternator belt keeps snapping. (Chiovnidca)
i cut my ac belt so i could put another alternator belt on, nothings locking up, it just snaps, it squeels for a long time, then just breaks.
Old May 21, 2006 | 12:35 PM
ED609's Avatar
Sounds like a pulley is siezing.
Old May 21, 2006 | 01:15 PM
Default Re: alternator belt keeps snapping. (ED609)
why do you say that?
Old May 21, 2006 | 01:34 PM
civic_dork's Avatar
I agree, sounds like a pulley is seizing.
Since in order for a belt to snap, it must have a whole ish load of strain put on it... and the only 2 possibilities for that are hard acceleration, or deceleration of the pulley/belt components. And we can pretty much rule out acceleration of the components, since the components in question are all designed well within tolerance of what the engine can possibly accelerate at (it'd throw rods or bearings before a belt)... we'll assume: YOUR ALTERNATOR is probably locking up.
Tricky part is figuring out if the alt is locking up due to the belt/pulley being misaligned or worn out... or if the alternator is borderline trashed... and heat build up is causing it to seize temporarily. I guess it could also be that the belt is getting pinched into the crankshaft pulley... but i'd only call that realistic with crappy aftermarket crank pulleys.
I had this problem on a 91 vDub i had... alternator was dying slowly.
gl
Old May 21, 2006 | 02:00 PM
Default Re: alternator belt keeps snapping. (civic_dork)
so im probably better off ordering my swap tomarrow?
Old May 21, 2006 | 02:08 PM
civic_dork's Avatar
ummm, that's up to you.
i'd fix it... but that's just me. then i'd order the swap stuff.
-- could also just be cheap belts? -- using oem or autozone trash?
ooor, maybe you're just putting them on too tight?
Old May 21, 2006 | 03:24 PM
ive litterly put like 9 on, ive changed the tightness losserness for the majority. no just i intend to do a swap anyways, and the belt keeps breaking and its getting annoying so now seems like the logical time to do it... i hope lol. yeah i am using belts from advanced auto, dont know where/how much the real ones are:\
Old May 21, 2006 | 03:38 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Dumbass &raquo;</TD></TR><TR><TD CLASS="quote">ive litterly put like 9 on, ive changed the tightness losserness for the majority. </TD></TR></TABLE>
Does the alt spin freely? Have you checked?
Old May 21, 2006 | 03:59 PM
SimplyTron's Avatar
Definetly change out the alternator. Defienetly sounds like its on its way out, starts to get alot of resistance (squealing) then snaps due to pressure.
dotay
Dec 30, 2006 01:35 PM
KOALA YUMMIES
Sep 23, 2005 09:05 AM
T--Rex
Jul 14, 2004 04:44 PM
keithv
Aug 7, 2002 04:40 AM
