heres some pics of my lude........any tips on cleaning her up???
Old May 21, 2006 | 11:44 AM
msinsky14's Avatar
Default heres some pics of my lude........any tips on cleaning her up???
my lude looks really nice on the outside, but the engine bay is really rusted and so is the underbody........what can I do to clean up the rust?........and does an aftermarket header go through that braided pipe and all the way to the cat?
[IMG][/IMG]
[img]https://i76.photobucket.com/albums/j29/sinskyballs/266dd01d.jpg[/img
Modified by msinsky14 at 12:58 PM 5/21/2006
Modified by msinsky14 at 1:04 PM 5/21/2006
Old May 21, 2006 | 11:56 AM
98vtec's Avatar
moderator emeritus
Default Re: heres some pics of my lude........any tips on cleaning her up??? (msinsky14)
PB blaster is awesome with taking out rust
it just depends on how deep the rust goes. Looks like there are a couple spots where you may be in some trouble.
Old May 21, 2006 | 11:59 AM
msinsky14's Avatar
Default Re: heres some pics of my lude........any tips on cleaning her up??? (98vtec)
what spots are in trouble?
Old May 21, 2006 | 12:00 PM
98vtec's Avatar
moderator emeritus
shock tower area and motor mounts.
Old May 21, 2006 | 12:02 PM
msinsky14's Avatar
what about that little thing that looks like a drum behind my driver's side headlight?
Old May 21, 2006 | 12:03 PM
98vtec's Avatar
moderator emeritus
part of the engine bay where the shocks are bolted to........
Old May 21, 2006 | 12:05 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">what about that little thing that looks like a drum behind my driver's side headlight?</TD></TR></TABLE>
the cruise control?
that looks ok. Take some PB blaster to that and let it soak for a little bit. Then take a bristle pad and scrub it down, then clean it off with a wet rag.
Old May 21, 2006 | 12:06 PM
msinsky14's Avatar
yeah, and what about underneath??
Old May 21, 2006 | 12:07 PM
msinsky14's Avatar
whats PB blaster?
Old May 21, 2006 | 12:08 PM
98vtec's Avatar
moderator emeritus
have fun with that. You cant ever tell the true extent of rust damage until you actually get in there and try to take it out.
Old May 21, 2006 | 12:09 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">whats PB blaster?</TD></TR></TABLE>
you can get it at any auto parts store
Old May 21, 2006 | 12:17 PM
msinsky14's Avatar
Default Re: heres some pics of my lude........any tips on cleaning her up??? (apeng09)
oh i know I want to change my interior over to black after I fix this stuff................I live in northern Ohio and it has 118,000 miles on it........everything runs well but that braided exhaust pipe is leaking out some loud sounds from it.....whats ur AIM?
Modified by msinsky14 at 1:33 PM 5/21/2006
Old May 21, 2006 | 01:45 PM
VtecFreePrelude's Avatar
how northern ohio?
i'm in cincyso probably a lot more than me but o well
the header goes to the cat. new ones come with both pieces and will probably help
mine had some bad noise from my cat until i replace it with a straight through cat
and the blaster is the best thing to use for stuck bolts. just don't get it on anything rubber or polyurethane.
if you do clean it off quick
Old May 21, 2006 | 02:09 PM
msinsky14's Avatar
Default Re: (VtecFreePrelude)
I was told the blaster will work to get rust off of anything metal, not just to undo bolts......but will it help undo rusted bolts when lowering the car?
Old May 21, 2006 | 02:30 PM
Hawkze_2.3's Avatar
Default Re: (msinsky14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">I was told the blaster will work to get rust off of anything metal, not just to undo bolts......but will it help undo rusted bolts when lowering the car?</TD></TR></TABLE>
No, rust has to be sanded off or you can use Scotch-brite or steel wool to get it off. I paint military vehicles and parts every single day and those things are always rusted to ****. We use $125/gallon rust preventative primer & paint and we still have to sand it off first.
So get you some fine sandpaper, steel wool or Scotch-brite pads and sand it off.
Old May 21, 2006 | 03:18 PM
Silver Surfer's Avatar
those vacuum hoses look pretty rough, i would look into get some new ones and maybe replace a few of your other hoses
Old May 21, 2006 | 03:19 PM
msinsky14's Avatar
Default Re: (Hawkze_2.3)
but will it scrape off the paint too??......like on thr pic of the shock mount?
Old May 21, 2006 | 04:09 PM
msinsky14's Avatar
Default Re: (Silver Surfer)
the weird this is that all the engine rust is on the driver's side, theres only a little normal grime on my passenger side....how would water be getting in there????
Old May 21, 2006 | 04:30 PM
masters101's Avatar
how much did you pay for it?
Old May 21, 2006 | 04:35 PM
msinsky14's Avatar
Default Re: (masters101)
4300 with 117,000 mileseverything works wonderfully mechanically wise, but it just looks bad
Old May 21, 2006 | 04:41 PM
forsaken787's Avatar
the first thing i would do is bring it to the car wash and pressure wash the engine bay with castrol syntech the BEST degreaser available.
Old May 21, 2006 | 04:43 PM
msinsky14's Avatar
Default Re: heres some pics of my lude........any tips on cleaning her up??? (forsaken787)
isnt that motor oil???and even if wouldnt that be a bad idea to throw water around in the engine bay with rus tthere already?
Old May 21, 2006 | 05:26 PM
sykotik sol's Avatar
too rusted, too blue inside, too much stuff.........
SELL IT!
Old May 21, 2006 | 05:49 PM
msinsky14's Avatar
Default Re: heres some pics of my lude........any tips on cleaning her up??? (sykotik sol)
why sell it, I just bought it, I wanted silver, but now I have to deal with the blue interior......I might change it out soon
Old May 21, 2006 | 06:12 PM
B7AudiA4's Avatar
looks like someone took a dump.
good luck
