ls/vtec
Old May 21, 2006 | 10:51 AM
95_red_dc's Avatar
Default ls/vtec
i have a b18b and i want more powerso i was thinkg about doing ls/vtec and i wanted some opions on it whos done it and how it was and how much more power should i see from itthe pros and cons of itand what is the best way of putting a vtec head on and which one would be better a b16 or a b18
Old May 21, 2006 | 10:55 AM
sirhatch90's Avatar
Default Re: ls/vtec (91cleancrxsi)
i would say b18 because it has a bigger displacement but, ls vtech are expensive to build right and if you dont then boom goes you enginge.
Old May 21, 2006 | 11:09 AM
EF'n Sedan's Avatar
Default Re: ls/vtec (sirhatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatch90 &raquo;</TD></TR><TR><TD CLASS="quote">i would say b18 because it has a bigger displacement but, ls vtech are expensive to build right and if you dont then boom goes you enginge.</TD></TR></TABLE>
wtf?
i think he was asking about which head to use,i'm not 100% sure but i think the GsR head yields 0.2 more compression than a B16! but it all depends on what all u plan on doin to the motor N/A or bOOst!!
Old May 21, 2006 | 11:14 AM
sirhatch90's Avatar
Default Re: ls/vtec (EF'n SEDAN)
yeh that might be it sorry i might of read it wrong
Old May 21, 2006 | 11:16 AM
95_red_dc's Avatar
i do not have any plains to do piston or rods and i know thatb b18b are not good for hi revving but if i get a vtec controller a get it tuned would it help and be reliable
Old May 21, 2006 | 11:51 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91cleancrxsi &raquo;</TD></TR><TR><TD CLASS="quote">i do not have any plains to do piston or rods and i know thatb b18b are not good for hi revving but if i get a vtec controller a get it tuned would it help and be reliable</TD></TR></TABLE>
no.
It has to do with the bottom end mostly the rods and rod bolts.
I have shotpeened polished ls rods and arp bolts i spin to 8500 no problem.
Vtec controller = wak.
Old May 21, 2006 | 12:44 PM
Mugencrxsir1's Avatar
Default Re: ls/vtec (***-assin)
b16 head, cheaper, easier to find, and actually flows slightly better than the b18 head. There's dyno charts on HT that show the difference, but really which ever head you can get for cheaper. I paid $550 shipped for a complete b16 head off ebay(alot of aftermarket crap came with it). Look to pay around $400-$600 for a head depending on how complete, mileage, wear, aftermarket parts etc....
Old May 21, 2006 | 12:52 PM
All Motor Ek99's Avatar
lsvtec is very expensive if built up fully and rite
Old May 21, 2006 | 01:13 PM
Ass$nyper's Avatar
Default Re: (NA-Ef8 (626 Moderator))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA-Ef8 (626 Moderator) &raquo;</TD></TR><TR><TD CLASS="quote">lsvtec is very expensive if built up fully and rite</TD></TR></TABLE>
ROFL.
no.
Old May 22, 2006 | 03:31 PM
VtecMakesUGod's Avatar
Default Re: (***-assin)
ls vtec is a b18 bottom end and a b16 head. if u put a b16 head on a b18 u get high compression. if u put a b18 head u have basically a gsr and ur wasting ur time.
Old May 22, 2006 | 03:36 PM
Ass$nyper's Avatar
Default Re: (VtecMakesUGod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecMakesUGod &raquo;</TD></TR><TR><TD CLASS="quote">ls vtec is a b18 bottom end and a b16 head. if u put a b16 head on a b18 u get high compression. if u put a b18 head u have basically a gsr and ur wasting ur time. </TD></TR></TABLE>
lmfaooo
you don't even have a d15b2 do you?
Old May 22, 2006 | 04:34 PM
si0385.'s Avatar
its not that expencive... check my sig i just about got everything i need and still havent spent 1500...
gota go spend another 200 this week though because they machine shop broke my pr3 pistons so im gona go pick up a set of p30 new from honda
Old May 22, 2006 | 05:01 PM
SlobberGoat's Avatar
Default Re: (si0385.)
So if I wanted to have a bit of a play at building an DIY LS/VTEC setup.
Is it at all possible to simply source a B18 block and a B16 head and simply slap them together for a little fun? or is fitting aftermarket components a must?
Old May 22, 2006 | 05:05 PM
si0385.'s Avatar
everything inside my motor is all oem honda...
the only thing that is needed aftermarket is the ls/vtec kit and its not neccicairy but its helpfull
Old May 22, 2006 | 05:11 PM
Autoworks's Avatar
B16 head is proven to flow better, and a LS-VTEC, is not necissarily "expensive"
A VTEC controlle rwill not make it more reliable, tuning will. A VTEC controller IMO is pointless if you are running a tunable program that allows you to set vtec engagement through the program.
Try again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">everything inside my motor is all oem honda...
ll</TD></TR></TABLE>
I've seen several stock bottom end LSVTEC setups with built heads make good power and hold up fine.
Old May 23, 2006 | 05:04 PM
si0385.'s Avatar
Default Re: ls/vtec (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
I've seen several stock bottom end LSVTEC setups with built heads make good power and hold up fine. </TD></TR></TABLE>
its oem honda not stock the only thing that is stock that i would really like to change is the rods but i do kind of like the idea of an all oem internal motor that can run a low 13, i do have arp rod bolts just so i can twist the motor a lil higher and not have to wory about spinnging bearing
Old May 23, 2006 | 05:55 PM
Bjorn20's Avatar
i say get a ctr head, and build the ls block a little so you can rev the **** out of it if you wanted to (thats what the ctr is made for)
Old May 23, 2006 | 06:00 PM
Autoworks's Avatar
Default Re: ls/vtec (Bjorn20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">i say get a ctr head, and build the ls block a little so you can rev the **** out of it if you wanted to (thats what the ctr is made for)
You'de never find one
mike integra
Sep 28, 2008 05:26 AM
ser13
Apr 18, 2007 11:59 PM
95_red_dc
May 21, 2006 03:13 PM
RJH6
Feb 7, 2005 10:02 PM
Methane2k2
Nov 21, 2004 05:45 PM
