Leaking oil from dizzy HELP!!!!
Old May 21, 2006 | 09:48 AM
hondachris1994's Avatar
Default Leaking oil from dizzy HELP!!!!
I replaced the O ring and still leaks WTF any help would b appreciated
Old May 21, 2006 | 10:31 AM
Default Re: Leaking oil from dizzy HELP!!!! (hondachris1994)
anyone ever have this problem?
Old May 21, 2006 | 10:54 AM
jmk2888's Avatar
Could it be the Cam Seal ?
Old May 21, 2006 | 11:00 AM
IVAN93EG's Avatar
Default Re: Leaking oil from dizzy HELP!!!! (jmk2888)
i had the same problem last month. the honda dealership said there is a seal in the dizzy that cant be serviced. im not sure if this is true.i just bought a used one from a friend and no more leak. leaks suck!
Old May 21, 2006 | 10:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 &raquo;</TD></TR><TR><TD CLASS="quote">Could it be the Cam Seal ?</TD></TR></TABLE>camsel is on the other side of the head so no it couldnt b that
Old May 22, 2006 | 06:02 AM
anyone?
Old May 22, 2006 | 06:45 AM
w0ng_sta's Avatar
sorry.. possible noob question but whats a dizzy?
Old May 22, 2006 | 08:56 AM
Default Re: Leaking oil from dizzy HELP!!!! (w0ng_sta)
distributor
Old May 22, 2006 | 09:46 AM
anyone else?
Old May 22, 2006 | 09:49 AM
Andres-eh2's Avatar
check the valve cover gasket (put copper seal on the edges right before the bump for the cam) and make sure that cap where the top bolt of the dizzy goes is torqued to spec onto the head
Old May 22, 2006 | 10:24 AM
JOE-C's Avatar
degrease the area and monitor it.
Old May 23, 2006 | 09:39 AM
Default Re: Leaking oil from dizzy HELP!!!! (JOE-C)
maybe it is the cam seal, is there a cam seal rt by the dizzy?
Old May 23, 2006 | 10:29 AM
Turbo E's Avatar
there is a brass bushing/seal on the dizzy shaft. you need to buy a rebuilt dizzy and swap over the internals.
i tired looking for rebuld kits, no luck.
Old May 23, 2006 | 10:31 AM
bsixteen's Avatar
napa sells refurbished dizzy's. i got mine from there
Old May 23, 2006 | 10:36 AM
PhatBoy5015's Avatar
Default Re: (bsixteen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bsixteen &raquo;</TD></TR><TR><TD CLASS="quote">napa sells refurbished dizzy's. i got mine from there</TD></TR></TABLE>
How much was it?
Old May 23, 2006 | 10:47 AM
Default Re: (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E &raquo;</TD></TR><TR><TD CLASS="quote">there is a brass bushing/seal on the dizzy shaft. you need to buy a rebuilt dizzy and swap over the internals.
i tired looking for rebuld kits, no luck.</TD></TR></TABLE>But the dizzy I have is a MSD dizzy and its like a month old
Old May 24, 2006 | 08:13 AM
Turbo E's Avatar
Default Re: (hondachris1994)
well take it back for warranty IMO. otherwise clean up the insides and run it for a bit to see where the oil is coming from
Old May 24, 2006 | 09:38 AM
Im thinkin its the cam seal
Old May 24, 2006 | 10:26 AM
Out of every
what motor is it? if its a b series vtec then replace the vtec solenoid gasket. my problem
Old May 24, 2006 | 01:50 PM
lcjarrett's Avatar
Default Re: (e gee two)
THis dude know what he is talking about....I am having the same problem. Where do you get a Vtec Solilend seal from?
Old May 24, 2006 | 01:51 PM
lcjarrett's Avatar
I mean solenoid gasket from? I need one bad my **** is leaking too!!!
Old May 25, 2006 | 12:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">what motor is it? if its a b series vtec then replace the vtec solenoid gasket. my problem </TD></TR></TABLE>Its a b16 but its clearly comin from the dizzy area so this weekend ima change the cam seal cause I already replaced the dizzy Oring
Old May 25, 2006 | 12:39 AM
Out of every
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">Its a b16 but its clearly comin from the dizzy area so this weekend ima change the cam seal cause I already replaced the dizzy Oring</TD></TR></TABLE>
mine also looked as if it was coming from the dizzy. how could you say it might be the cam seal when the vtec solenoid is right there also. do what you want i say you spend 16 bucks and replace the vtec solenoid gasket first. its a good thing to replace that anyway. try that first if the leakage presists then by all means do the cam seal. imo do the easy things first and then the more complicated
3 main things to cause oil leakage in that area
cam seal
dizzy o ring
vtec solenoid good luck
Old May 27, 2006 | 04:41 PM
bsixteen's Avatar
Default Re: (PhatBoy5015)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 &raquo;</TD></TR><TR><TD CLASS="quote">
How much was it?</TD></TR></TABLE>
i bought it like a year ago...i dunno...$100-140? cant remember
Old May 27, 2006 | 06:38 PM
cam seal
dizzy o ring
vtec solenoid good luck</TD></TR></TABLE>Im thinkin cam seal
Ha Itz
Jan 2, 2007 05:57 PM
hondachris1994
17
Aug 21, 2006 08:42 AM
eluder33
Apr 18, 2006 05:25 PM
Out of every "game"
Apr 16, 2006 02:41 PM
Out of every "game"
Apr 16, 2006 02:14 PM
