h22 in eg won't start
Old May 21, 2006 | 06:35 AM
civichbb18's Avatar
Default h22 in eg won't start
hi i have a 1992 civic eg and i put a h22 in with an external coil, i had a msd box and coil on car already i am trying to get spark. i took the white wire from msd box and hooked it to yellow green wire on distributor harness and the red wire from msd to the black yellow plug on harness. then it pops when you first crank it and then turns over with out any sign of starting i have new spark plugs and it has compression. please help this is my daily driver and i need it back on road. thanks ryan
Old May 21, 2006 | 12:11 PM
civichbb18's Avatar
Default Re: h22 in eg won't start (civichbb18)
help i need this car to run the timming is on any ideas help
Old May 22, 2006 | 03:07 PM
civichbb18's Avatar
help i dont think i have the right spark
Old May 23, 2006 | 04:07 AM
Mikey3000's Avatar
have u tried starting it w/o the msd box? does the motor crank at all?
nikko_SOHC
May 29, 2009 12:27 AM
ahtublao
Aug 21, 2008 11:05 AM
RaceCarRyne
Sep 2, 2007 11:32 AM
4drsedaneg
May 22, 2006 07:42 PM
