91 4door automatic (dpfi -> mpfi)+(d16a6 motor only) swap questions
Old May 21, 2006 | 01:14 AM
mengy007's Avatar
Default 91 4door automatic (dpfi -> mpfi)+(d16a6 motor only) swap questions
Well first of all I would like to say that I have searched and researched the information on how to do the dpfi -> mpfi swap. My concern now is that I want to keep my automatic trannny. I'm planning on using a PR4 automatic ecu from an integra. The question is will I have to do anything special because it is an automatic? Do I need to worry about wires for the auto tranny? Will the PR4 automatic ECU work for my auto tranny? Will the throttle cables work?
Old May 21, 2006 | 03:46 AM
Sikocivic's Avatar
Default Re: 91 4door automatic (dpfi -> mpfi)+(d16a6 motor only) swap questions (mengy007)
You could get a PS9 ECU from a 90-91 Civic EX 4dr. They had the MPFI Si motor with an automatic tranny.
Old May 21, 2006 | 10:55 AM
mengy007's Avatar
Default Re: 91 4door automatic (Sikocivic)
I couldn't find any on ebay.. I'll have to hit up the junk yards... but would the automatic pr4 work?
Old May 21, 2006 | 12:02 PM
little white crx's Avatar
Default Re: 91 4door automatic (mengy007)
im running a pg7 standard tranny ecu on my auto mpfi d16a6.
so you can use a standard trans ecu, only catch is there is no way to hook up the lock up torque converter (not a big deal only locks up the converter to save gas at high way speeds) everything else works great.
however, hooking up the kick down cable is tricky make sure its perfect or the trans will up shift early at full throttle and downshift really really hard all the time. i ended up having to custom make my own cable that hooks up to the kick down lever then goes though the fire wall and hooks to the gas pedal.
difference in right and wrong is 9.87 to 10.23 in the 1/8th mile
you may even try the pr4 just to see if it works.
Old May 21, 2006 | 04:47 PM
mengy007's Avatar
Default Re: 91 4door automatic (little white crx)
that's great I also have a standard PG7 ecu that I can use if the PR4 doesn't work... as far as mpfi swap goes do I need extra wires for the auto trans?
Old May 21, 2006 | 04:57 PM
no the obd0 auto trans shifts are not controlled electronicly. therefore the the only wire that goes to the trans is the torque converter lock up.
Old May 21, 2006 | 05:17 PM
mengy007's Avatar
Thank you, thats what I needed to know.
Old May 21, 2006 | 05:26 PM
mengy007's Avatar
By the way this is the guide I'm using.
http://crf50.no-ip.com/fourthgenhatch/mpfi.html
lil90crxman
Aug 31, 2009 03:19 PM
bonies
24
Aug 30, 2009 11:00 PM
wooferwagon
Nov 3, 2004 07:19 AM
Vinceg99
13
Dec 19, 2002 11:20 AM
wronghand
Jun 6, 2002 04:53 PM
