Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Race/ Street seat?...search function is still busted :(
Old Apr 12, 2002 | 11:24 AM
N24RE's Avatar
Default Race/ Street seat?...search function is still busted :(
Ok...I would have looked this up in the archive,but I can't.
So here goes
I need to eventually replace the two front seats with something that has the harness holes for the shoulder and sub belts. What is the best bang for the buck. I wnt it cheap....I could care less about JDM or any of that other stuff. I still need the recline function. I will only be doing HPDE and time trials with this car
I looked at the Sparcos $$$
What about the Tenzo's???
thanks
Old Apr 12, 2002 | 11:27 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: Race/ Street seat?...search function is still busted :( (N24RE)
Steve, Tenzos focking suck. they feel like crap when you sit in them, the fabric licks *** also. you really get what you pay for with those things.
Recaro SRDs are nice, around 650 bux I think (asked some VW guy with them in his car)
Old Apr 12, 2002 | 11:30 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Kirkey.
Little much for street, but you want a cheap, well constructed quality piece, that is the ticket.
Old Apr 12, 2002 | 12:41 PM
Solo2Vtec's Avatar
USDM Recaro SRD
Old Apr 12, 2002 | 12:42 PM
robbin's Avatar
Default Re: Race/ Street seat?...search function is still busted :( (madhatter)
Kirkey's don't recline though, do they?
Old Apr 12, 2002 | 12:47 PM
johng's Avatar
Default Re: Race/ Street seat?...search function is still busted :( (robbin)
Try http://www.corbeau.com
Old Apr 12, 2002 | 01:14 PM
Warren's Avatar
Wrong-Way Wang
I have 1 reclining OMP seat in my M3. I have no idea if it is any good. I never sit in the passenger's seat. No one has complained though, except about having to figure out the 5 point harnesses
Warren
Old Apr 12, 2002 | 01:20 PM
Crack Monkey's Avatar
If you are serious about time-trials, you really should consider a properly installed bucket seat. They are much safer than reclinables.
Can'y you use a harness with the stock seat? Just pull off the bottom cushion and cut through the foam. Have somebody sew a hole into the fabric cover. Much cheaper than buying all-new seats.
Old Apr 12, 2002 | 01:41 PM
GRM Scott's Avatar
25 Year Member
Default Re: Race/ Street seat?...search function is still busted :( (Crack Monkey)
my bucket Sparco Evo is oddly more comfortable than the stock R seats...i must have spent 20 hours in it over a weekend, racing and highway, and i was absolutely fine, while my back usually bugs me after about 4-5 hours in a stock seat. Get a shell that fits you like a glove, and you'll never go back. I feel like i could do 24eme du mans in this thing nonstop
Old Apr 12, 2002 | 01:58 PM
manveer's Avatar
Default Re: Race/ Street seat?...search function is still busted :( (Aleph)
I can sit in my Corbeau Forza for a good 4-5 hours before it gets uncomfortable. I have no problem with the straight-up design, since I used to put the stock seat at the setting closest to vertical anyway. Maybe I'm just odd, but it feels plenty comfy to me.
Old Apr 12, 2002 | 05:13 PM
Geezer's Avatar
Can't you use a harness with the stock seat? Just pull off the bottom cushion and cut through the foam. Have somebody sew a hole into the fabric cover. Much cheaper than buying all-new seats.
Of course, if you want to run STS in autox, the SCCA, in its infinite wisdom, has decided that you <u>must</u> have a reclining seat...and none of the reclining seats I've seen have a cutout for the anti-sub strap. Even for STX, the best you can use is a tube frame racing seat, not the safer shell types.
I have this problem, and so far just use the stock seat with the crotch belt around the front. I was thinking about cutting through the seat as CM suggests, but the bottom of the Civic Si seat is almost entirely covered with sheet metal, so it's a bit more of a project. I was thinking I might try a two strap anti-sub setup that loops under the legs and hooks to the same places as the lap belt.
Caoboy
22
Mar 19, 2015 06:28 PM
577HondaPrelude
Nov 26, 2003 10:55 AM
Dan GSR
Oct 22, 2002 07:56 PM
jw
Sep 8, 2002 12:38 PM
civicrtype
Jul 28, 2002 03:28 PM
