Help with broken door handle
Old Apr 12, 2002 | 11:03 AM
Thrillhouse's Avatar
Default Help with broken door handle
I need a step by step on how to remove the door panel on my 92 civic lx. The exterior door handle is stuck in an outward position and i want to get in side the panel to fix it but i cant firgur it out please help!!!!! Thank you guys for your comments
Old Apr 12, 2002 | 12:44 PM
94CivicSi's Avatar
Default Re: Help with broken door handle (Thrillhouse)
power windows or manual?
I have a hatch, but I'll assume they mount the same way.
1) remove the screw inside the door pull.
2) remove the screw hidden by the dash when the door is closed.
2b) edit: I forgot, there's also a screw inside the door handle on the inside.
3) remove the window crank (manual). There's a spring clip on the back. Use a pick to hook the clip and pull. If you have power windows, you should just be able to remove the panel and unplug it.
4) Pull up then out on the door panel.
5) CAREFULLY pull back the plastic. There's some sticky *** glue holding it onto the door. Try not to tear the plastic. There's a small tear in mine and when I crack the window in the winter, cold air pours in though the speaker grill.
Good luck.
[Modified by 94CivicSi, 11:03 PM 4/12/2002]
Old Apr 14, 2002 | 09:44 AM
Thx but the panel is getting stuck on the interior door handle and the top where it has the rubber gasket for the window. BTW its a rear door, automatic windows.
Old Apr 14, 2002 | 11:30 AM
B_CRUZ!'s Avatar
lift door panel up.
206civic
Jan 8, 2005 11:43 AM
jmmeye5
Dec 5, 2004 10:27 AM
eddie1681
Feb 24, 2003 10:33 PM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
serious
Sep 6, 2002 04:40 PM
